Did my Installation get corrupt?
So, I can give you all an update. I sort of figured it out.
Immich currently doesn’t support proper cleanup of failed uploads, meaning they just sit there on your disk doing nothing except for consuming your valuable bytes.
What I did is I’ve created a storage template, what Immich then is able to do is run a migration from all you’re previously uploaded files and put them into your library according the template you’ve created.
So this is how my “Rotzooi” dataset now looks like:
NAME                                                       USED  AVAIL  REFER  MOUNTPOINT
Rotzooi                                                    890G  8.79G    96K  /mnt/Rotzooi
Rotzooi@manual-2024-11-28_19-27                              0B      -    96K  -
Rotzooi/.system                                           1.55G  8.79G  1.12G  legacy
Rotzooi/.system/configs-ae32c386e13840b2bf9c0083275e7941  2.08M  8.79G  2.08M  legacy
Rotzooi/.system/cores                                       96K  1024M    96K  legacy
Rotzooi/.system/netdata-ae32c386e13840b2bf9c0083275e7941   432M  8.79G   432M  legacy
Rotzooi/.system/nfs                                        124K  8.79G   124K  legacy
Rotzooi/.system/samba4                                     212K  8.79G   212K  legacy
Rotzooi/ix-apps                                            889G  8.79G   120K  /mnt/.ix-apps
Rotzooi/ix-apps/app_configs                                712K  8.79G   712K  /mnt/.ix-apps/app_configs
Rotzooi/ix-apps/app_mounts                                 883G  8.79G    96K  /mnt/.ix-apps/app_mounts
Rotzooi/ix-apps/app_mounts/immich                          883G  8.79G   112K  /mnt/.ix-apps/app_mounts/immich
Rotzooi/ix-apps/app_mounts/immich/backups                 2.00G  8.79G  2.00G  /mnt/.ix-apps/app_mounts/immich/backups
Rotzooi/ix-apps/app_mounts/immich/library                  **207G**  8.79G   207G  /mnt/.ix-apps/app_mounts/immich/library
Rotzooi/ix-apps/app_mounts/immich/pgBackup                  96K  8.79G    96K  /mnt/.ix-apps/app_mounts/immich/pgBackup
Rotzooi/ix-apps/app_mounts/immich/pgData                   370M  8.79G   370M  /mnt/.ix-apps/app_mounts/immich/pgData
Rotzooi/ix-apps/app_mounts/immich/profile                  472K  8.79G   472K  /mnt/.ix-apps/app_mounts/immich/profile
Rotzooi/ix-apps/app_mounts/immich/thumbs                  6.05G  8.79G  6.05G  /mnt/.ix-apps/app_mounts/immich/thumbs
Rotzooi/ix-apps/app_mounts/immich/uploads                  **634G**  8.79G   634G  /mnt/.ix-apps/app_mounts/immich/uploads
Rotzooi/ix-apps/app_mounts/immich/video                   34.3G  8.79G  34.3G  /mnt/.ix-apps/app_mounts/immich/video
Rotzooi/ix-apps/docker                                    5.60G  8.79G  5.60G  /mnt/.ix-apps/docker
Rotzooi/ix-apps/truenas_catalog                           66.2M  8.79G  66.2M  /mnt/.ix-apps/truenas_catalog
I’ve asked on the Immich discord, and they said I could now remove all content from my uploads folder, but before I do this, I rather first make a snapshot of the dataset so I’ve got something to return to if shit hits the fan.
Now I need to remove all subfolders that are stored within the Uploads folder, but I need to keep the uploads folder alive. So what I did was:
sudo rm -rf /mnt/.ix-apps/app_mounts/immich/uploads/*
Which was scary to do at first. But I did it anyways :rofl:
And now we have our space back! :smiley:
