All the videos, forums and tutorials that I studied show, under tls-settings, the option to select a certificate, but for me this option does not appear and I cannot assign my certificate to an app.
I have already configured Truenass and ACME certificates through Cloudflare. but without success in selecting the certificates in the apps.
All the video tutorials and most guids not directly provided by truecharts are out of date. If you want to add a cert to an app you need two additional apps namely cert-manager and cluster issuer, which now provide the certs for their apps.
See clusterissuer Setup Guide | TrueCharts
Of course you can’t–your internal NAS IP is a private IP address that isn’t routable across the public Internet. You’d need to set that to your public IP, and then port-forward on your router, to make this accessible–but exposing your NAS to the public Internet is strongly discouraged.
A-Record should be your public ip adresse, you can find it on pages like whatsmyip.com
For each app you then want to expose you have to create cnames. Those cnames then need to be added to the ingress section of the app you want to expose.
You also need Traefik as reverse proxy for it all to work and come together.
Your best bet would be the truecharts support on their discord, they’re far better at diagnosing problems then i am.
Since i never had problems during my setup i’m not the best to ask for troubleshooting
