Disk errors only when using SMB, not when using NFS
I have an interesting situation.
I am in the process of moving from multiple separate Synology NAS to a new 45HomeLab HL15 (1.0) running TrueNAS scale 24.05.01.
ISSUE:
I started moving over 100TB of data over to the system off my Synology Units. I used NFSv4 mounts inside the Synology units to mount the NFS shares from the HL15.
The data copied over without issue, no errors etc. The data was copying over at only ~111 MB/s due to the 1GB Ethernet connections on my Synology Units.
I then started to perform CRC checks of the files using windows SMB, but using two computers concurrently again only over 1GB Ethernet as my desktop and laptop only have 1GB Ethernet ports allowing to get 2.0 Gb per second on the CRC checks.
It can be seen from the reporting page on TrueNAS that every time a drive timed out during SMB transfers, the data transfer stopped for that volume.
The drive issues ONLY occur when using SMB transfers. I get ZERO drive errors when using NFS when mapping the SAME data set and performing CRCs on the SAME files. I even stopped using SMB shares on the windows machine and mounted my TrueNAS NFS share on windows 11 and when using the NFS share, i again get ZERO issues. The drive errors only occur when using SMB.
the fact that accessing the same data on the same drives in the system using the same two windows 11 machines using the same CRC verification program ONLY cause drive errors when using SMB seems to point to this issue NOT being a hardware issue, but a software issue.
Any ideas?
System:
SuperMicro X11SPH-nCTPF
Corsair XM1000
Xeon Silver
128GB ECC RAM
Added cards:
Nvidia RTX A400
LSI-9400-8e tied to DELL N4C2D JBOD 24 internal 12 external lane SAS2 6Gbps expander board
3x Micron 1.92TB SSDs
LSI-9400-8i
replacing the motherboard integrated Intel 3008 controller. The 3008 controller is physically disabled by motherboard jumper pin
4 port 1GB Ethernet Intel i350 Chip-set
HDD details
slots 10 through 15 [running through LSI 9400-8i]: WD Gold 18TB drives (WDC WD181KRYZ-01 Firmware: 1H01)
slots 1 through 5 [running through motherboard SATA controller]: WD Gold 18TB drives (WDC WD181KRYZ-01 Firmware: 1H01)
slot 6 [running through motherboard SATA controller]: WD purple 8TB drive (WDC WD82PURZ-85T Firmware: 0A82)
root@truenas[~]# lsscsi
[0:0:0:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sda	/volume2
[0:0:1:0]    disk    ATA      WDC WD82PURZ-85T 0A82  /dev/sdg	/volume5
[0:0:2:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdi	/volume2
[0:0:3:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdc	/volume2
[0:0:4:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdd	/volume2
[0:0:5:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdf	/volume2
[0:0:6:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sde	/volume2
[0:0:7:0]    enclosu BROADCOM VirtualSES       03    -
[3:0:0:0]    enclosu AHCI     SGPIO Enclosure  2.00  -
[4:0:0:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdb	/volume3
[5:0:0:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdk	/volume3
**[6:0:0:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdl	/volume3
[7:0:0:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdh	/volume3
**[8:0:0:0]    disk    ATA      WDC WD181KRYZ-01 1H01  /dev/sdj	/volume3
[12:0:0:0]   enclosu AHCI     SGPIO Enclosure  2.00  -
[13:0:0:0]   disk    ATA      Micron_5400_MTFD U002  /dev/sdm	/volume1
[13:0:1:0]   disk    ATA      Micron_5400_MTFD U002  /dev/sdn	/volume1
[13:0:2:0]   disk    ATA      Micron_5400_MTFD U002  /dev/sdo	/volume1
[13:0:3:0]   enclosu Dell     SAS EXP V0110    0500  -
[14:0:0:0]   cd/dvd  JetKVM   Virtual Media          /dev/sr0
[N:0:1:1]    disk    KINGSTON SNV3S1000G__1                     /dev/nvme0n1
root@truenas[~]# find -L /sys/bus/pci/devices/*/ata*/host*/target* -maxdepth 3 -name "sd*" 2>/dev/null | egrep block |egrep --colour '(ata[0-9]*)|(sd.*)'
/sys/bus/pci/devices/0000:00:17.0/ata3/host4/target4:0:0/4:0:0:0/block/sdb
/sys/bus/pci/devices/0000:00:17.0/ata4/host5/target5:0:0/5:0:0:0/block/sdk
/sys/bus/pci/devices/0000:00:17.0/ata5/host6/target6:0:0/6:0:0:0/block/sdl
/sys/bus/pci/devices/0000:00:17.0/ata6/host7/target7:0:0/7:0:0:0/block/sdh
/sys/bus/pci/devices/0000:00:17.0/ata7/host8/target8:0:0/8:0:0:0/block/sdj
I have four pools (i manually added the pool names to the output of the lsscsi command above)
one is for my apps and uses the SSDs and is Z1
one is for some of my data and uses 6x drives in Z1
one is for the rest of my data and uses 6x drives in Z1
the final is a single drive for Frigate surveillance recording
root@truenas[~]# zpool status
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:04 with 0 errors on Sun Jul  6 03:45:06 2025
        NAME         STATE     READ WRITE CKSUM
        boot-pool    ONLINE       0     0     0
          nvme0n1p3  ONLINE       0     0     0
errors: No known data errors
  pool: volume1
 state: ONLINE
  scan: scrub repaired 0B in 00:22:44 with 0 errors on Sun Jun 15 06:10:57 2025
        volume1                                   ONLINE       0     0     0
          raidz1-0                                ONLINE       0     0     0
            4596200f-3a52-4c76-a9db-9cc9faabaa9b  ONLINE       0     0     0
            49834b66-f515-4880-8109-b1f947a3365f  ONLINE       0     0     0
            4efb7611-233a-4c98-88c8-e325e4018666  ONLINE       0     0     0
  pool: volume2
 state: ONLINE
  scan: scrub repaired 0B in 07:12:40 with 0 errors on Sun Jun 15 13:24:50 2025
        volume2                                   ONLINE       0     0     0
            4c17130c-18e1-4039-a1c9-84746d532a64  ONLINE       0     0     0
            08d3a783-bd44-47ce-9fe2-c609d27b2068  ONLINE       0     0     0
            b3c7e3f4-86fe-45bd-8b10-c520ddf81377  ONLINE       0     0     0
            385b8d00-c5b3-4d72-a75d-3bffdcda5abe  ONLINE       0     0     0
            bcd7a35c-a74e-4dba-8033-912853232182  ONLINE       0     0     0
            c5d9c40a-0cee-480d-a1fd-170ae6efe486  ONLINE       0     0     0
  pool: volume3
 state: ONLINE
        volume3                                   ONLINE       0     0     0
            bc6cf883-dde3-4a60-9f74-8fc3f389faab  ONLINE       0     0     0
            8fe3c3d5-4213-4412-b162-081cd3580650  ONLINE       0     0     0
            d4140d27-be38-412f-843e-cf420187ee64  ONLINE       0     0     0
            004f830a-ac49-44e0-b0d3-d9f84a03288e  ONLINE       0     0     0
            1e1c7c7b-7c60-4602-8546-893c94f365bb  ONLINE       0     0     0
  pool: volume5
 state: ONLINE
        volume5                                 ONLINE       0     0     0
          c7f8210f-a2a3-4e43-bf97-be50d99620da  ONLINE       0     0     0
root@truenas[~]# dmesg | grep ata5
[    2.764142] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.764597] ata5.00: ATA-11: WDC WD181KRYZ-01AGBB0, 01.01H01, max UDMA/133
[    2.772909] ata5.00: 35156656128 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.774587] ata5.00: Features: NCQ-sndrcv NCQ-prio
[    2.787591] ata5.00: configured for UDMA/133
[829544.395755] ata5.00: exception Emask 0x0 SAct 0x1880002 SErr 0x0 action 0x6 frozen
[829544.396278] ata5.00: failed command: READ FPDMA QUEUED
[829544.396760] ata5.00: cmd 60/00:08:f8:48:12/08:00:32:07:00/40 tag 1 ncq dma 1048576 in
[829544.397713] ata5.00: status: { DRDY }
[829544.398181] ata5.00: failed command: READ FPDMA QUEUED
[829544.398648] ata5.00: cmd 60/00:98:a8:34:0c/05:00:96:07:00/40 tag 19 ncq dma 655360 in
[829544.399597] ata5.00: status: { DRDY }
[829544.400086] ata5.00: failed command: READ FPDMA QUEUED
[829544.400566] ata5.00: cmd 60/40:b8:78:48:12/00:00:32:07:00/40 tag 23 ncq dma 32768 in
[829544.401580] ata5.00: status: { DRDY }
[829544.402080] ata5.00: failed command: READ FPDMA QUEUED
[829544.402575] ata5.00: cmd 60/40:c0:b8:48:12/00:00:32:07:00/40 tag 24 ncq dma 32768 in
[829544.403375] ata5.00: status: { DRDY }
[829544.403799] ata5: hard resetting link
[829544.718017] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[829544.780035] ata5.00: configured for UDMA/133
[829544.780058] ata5: EH complete
[841426.885067] ata5.00: exception Emask 0x0 SAct 0xc84 SErr 0x0 action 0x6 frozen
[841426.885789] ata5.00: failed command: READ FPDMA QUEUED
[841426.886513] ata5.00: cmd 60/40:10:88:0c:e2/05:00:b2:07:00/40 tag 2 ncq dma 688128 in
[841426.887991] ata5.00: status: { DRDY }
[841426.888743] ata5.00: failed command: READ FPDMA QUEUED
[841426.889397] ata5.00: cmd 60/40:38:b0:d7:18/00:00:d2:01:00/40 tag 7 ncq dma 32768 in
[841426.890218] ata5.00: status: { DRDY }
[841426.890626] ata5.00: failed command: READ FPDMA QUEUED
[841426.891026] ata5.00: cmd 60/40:50:30:d8:18/00:00:d2:01:00/40 tag 10 ncq dma 32768 in
[841426.891843] ata5.00: status: { DRDY }
[841426.892245] ata5.00: failed command: READ FPDMA QUEUED
[841426.892645] ata5.00: cmd 60/00:58:48:11:e2/08:00:b2:07:00/40 tag 11 ncq dma 1048576 in
[841426.893482] ata5.00: status: { DRDY }
[841426.893890] ata5: hard resetting link
[841427.203255] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[841427.260908] ata5.00: configured for UDMA/133
[841427.260954] ata5: EH complete
root@truenas[~]# dmesg | grep ata7
[    2.454588] ata7: SATA max UDMA/133 abar m524288@0xaa700000 port 0xaa700300 irq 186 lpm-pol 0
[    2.764061] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.764516] ata7.00: ATA-11: WDC WD181KRYZ-01AGBB0, 01.01H01, max UDMA/133
[    2.772888] ata7.00: 35156656128 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.774568] ata7.00: Features: NCQ-sndrcv NCQ-prio
[    2.787810] ata7.00: configured for UDMA/133
[838055.874386] ata7.00: exception Emask 0x0 SAct 0x6018001f SErr 0x0 action 0x6 frozen
[838055.875473] ata7.00: failed command: READ FPDMA QUEUED
[838055.876346] ata7.00: cmd 60/80:00:10:be:4b/00:00:d4:07:00/40 tag 0 ncq dma 65536 in
[838055.877996] ata7.00: status: { DRDY }
[838055.878864] ata7.00: failed command: READ FPDMA QUEUED
[838055.879708] ata7.00: cmd 60/80:08:10:bd:4b/00:00:d4:07:00/40 tag 1 ncq dma 65536 in
[838055.881462] ata7.00: status: { DRDY }
[838055.882372] ata7.00: failed command: READ FPDMA QUEUED
[838055.883284] ata7.00: cmd 60/40:10:98:ac:4b/00:00:d4:07:00/40 tag 2 ncq dma 32768 in
[838055.885161] ata7.00: status: { DRDY }
[838055.886095] ata7.00: failed command: READ FPDMA QUEUED
[838055.887068] ata7.00: cmd 60/40:18:58:ac:4b/00:00:d4:07:00/40 tag 3 ncq dma 32768 in
[838055.889482] ata7.00: status: { DRDY }
[838055.890917] ata7.00: failed command: READ FPDMA QUEUED
[838055.891912] ata7.00: cmd 60/00:20:d0:c3:4b/01:00:d4:07:00/40 tag 4 ncq dma 131072 in
[838055.893768] ata7.00: status: { DRDY }
[838055.894705] ata7.00: failed command: READ FPDMA QUEUED
[838055.895508] ata7.00: cmd 60/80:98:58:af:4b/00:00:d4:07:00/40 tag 19 ncq dma 65536 in
[838055.897075] ata7.00: status: { DRDY }
[838055.897911] ata7.00: failed command: READ FPDMA QUEUED
[838055.898737] ata7.00: cmd 60/c0:a0:d0:b3:4b/00:00:d4:07:00/40 tag 20 ncq dma 98304 in
[838055.900235] ata7.00: status: { DRDY }
[838055.900947] ata7.00: failed command: READ FPDMA QUEUED
[838055.901662] ata7.00: cmd 60/00:e8:00:a1:08/04:00:fd:06:00/40 tag 29 ncq dma 524288 in
[838055.903131] ata7.00: status: { DRDY }
[838055.903847] ata7.00: failed command: READ FPDMA QUEUED
[838055.904500] ata7.00: cmd 60/40:f0:90:b6:4b/00:00:d4:07:00/40 tag 30 ncq dma 32768 in
[838055.905837] ata7.00: status: { DRDY }
[838055.906517] ata7: hard resetting link
[838056.216634] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[838056.293820] ata7.00: configured for UDMA/133
[838056.293845] ata7: EH complete
I am also getting power-on device reset errors for drives [0:0:2:0], [0:0:3:0], [0:0:4:0], and [0:0:5:0] which are different from the ata5 and ata7 errors above.
Really strange - not particularly helpful, but to confirm; hba on latest available firmware & has decent cooling?
If so, I’d imagine this to be a proper bug report…
I don’t see how SMB protocol could cause drive errors. Seems like quite a stretch.
i do not disagree, however when running through SMB, i get errors left and right within 20-30 mins and continuously during the transfer.
change to NFS, and now over 24 hours later (and counting), zero errors
i was leaning towards a bug report, but wanted to get insight from others before hand.
edit: yes, both HBAs are in IT mode and on the latest version FW 24.00.00.00, BIOS version 09.24.00.00_24.00.00.00
the 8e HBA is showing around 45C and the 8i is showing around 52C while under load.
Different usage patterns in applications can tickle faulty hardware differently.
no doubt that is true, but it is just strange that i am accessing the same files from the same drives and just the medium in which it is being sent out of the box to my windows PCs makes the difference. one would think that if there was a hardware issue like a bad cable, bad back plane, bad drive, bad HBA etc, that the actual ATA commands being sent to the drives/HBA would be the same?
i would imagine that regardless of of NFS or SMB, the methods to actually read the data into RAM so the NFS and or SMB deamons to interact with would be identical?
when you are right, you are right, after about 48 hours of transfer using NFS i got a single power-on device reset. so the errors are no occuring anywhere near as often, but they are still occuring :frowning:
think i found my issue and my fix
i have also stumbled upon another possibility.
this article
is talking about needed to turn off Native Command Queuing for all his WD gold 16tb drives by setting the queue depth to 1, and it has links to other articles and discussions about flawed NCQ in WD Golds in ZFS github from 2020…
I am using WD Gold 18TB drives…
i am going to use this script to set the queue length to a value of 1 for ONLY my WD gold 18TB drives. this will leave my micron 1.92TB SSDs and my WD Purple drive (for Frigate Surveillance) alone at their default queue lengths of 32.
#!/bin/sh
for i in /dev/sd? ; do
	#echo "$i"
	model=$(smartctl -i $i | grep "Device Model")
	if [[ "$model" =~ "Micron" ]] || [[ "$model" =~ "PURZ" ]]; then
		echo "skipping disk: $i --> $model"
	else
		echo "Disabling NCQ for disk $i"
		echo 1 > "/sys/block/${i/\/dev\/}/device/queue_depth"
	fi
done
so my plans are:
1.) set queue depth to 1, test system
2.) if still errors, then try setting libata.force=3.0G. while this will not affect one of my pools since it will always be running off an HBA, it would allow me to test my other pool connected to the motherboard SATA controller. this pool also gets errors on heavy loads so it will be worth testing. Assuming this fixes the issue, then i will worry about configuring the HBA controllers.
3.) if still errors, then i will try testing with BOTH libata.force=3.0G and the queue depth set to 1
so far after more than 30 hours, no errors on either pool when setting the queue depth to 1. i am going to keep testing, and trying to increase the queue depth to 2 and or 3 etc and see if anything errors out.
well, i do seem to have solved the issue.
transferring data to and from the server at around 600MB/s over SMB i did not have any errors when the queue depth was set to 1 while transferring 50TB off and 50TB back on to the system 10x times over and over again to both pools.
as soon as i set the queue depth to a value of 2 or higher, i begin getting the disk errors within a couple TB of transfer
