Disks with exported pools, help
So i came home from work only to find out my files weren’t accessible on jellyfin. Logged in to truenas and found out my pool was gone, under storage i had disks with exported pools and i have no option to import an existing pool.
admin@truenas[~]$ sudo zpool import
[sudo] password for admin:
pool: Universe
state: ONLINE
status: Some supported features are not enabled on the pool.
(Note that they may be intentionally disabled if the
‘compatibility’ property is set.)
action: The pool can be imported using its name or numeric identifier, though
some features will not be available without an explicit ‘zpool upgrade’.
    Universe                                ONLINE
      7f54437a-3f1b-48f3-af6d-a1dbc169a5f3  ONLINE
      indirect-1                            ONLINE
      09bb512a-d496-45c5-9cf8-4dd75695ff41  ONLINE
    logs
      85a99299-287e-47d6-8d14-b0049ff07e47  ONLINE
No clue why it happend, is there a way to import the pool without data loss?
AMD Ryzen 5 3600 6-Core Processor
32 gb 3600 corsair
silverstone 650 w
tuf gaming b550m
HDD ST8000NM0105
HDD ST10000DM0004-1ZC101
Add pool, then import existing is not available in the UI?
It doesn’t show up ass existing pool, I would show images but it won’t let me attach media it says
“Universe” was a stripe of three single drive vdevs, and you have removed one (“indirect-1”), correct?
There was a nasty bug involving block cloning and indirect vdevs; if you’ve been bitten, the pool is lost. So… do you have a backup?
I have not removed any drive, i do not know what indirect-1 means.
What version of truenas is this bug present, i am on 25.04.2.4
How many physical drives did you have and what was the configuration we should be seeing?
Browse some other threads and do the Tutorial by the Bot to get your forum trust level up and post images and links
TrueNAS-Bot
Type this in a new reply and send to bring up the tutorial, if you haven’t done it already.
@TrueNAS-Bot start tutorial
my original configuration is a stripe of one drive and one cache, which i later expanded with another drive. totalling two drives (8tb + 10tb) stripe and one for cache (500gb sdd). it happened over night, haven’t physically touched or removed anything on the admin page. i run SMART tests and SCRUB, which have not shown errors from what i can tell.
I found a post with a similar issue and it suggested a few commands to try. I came closer but still stuck with not pool able to import.
The following commands gave this result:
admin@truenas[~]$ sudo zpool import Universe
cannot import ‘Universe’: I/O error
Recovery is possible, but will result in some data loss.
Returning the pool to its state as of Mon Oct 13 23:45:54 2025
should correct the problem. Approximately 30 seconds of data
must be discarded, irreversibly. Recovery can be attempted
by executing ‘zpool import -F Universe’. A scrub of the pool
is strongly recommended after recovery.
admin@truenas[~]$ sudo zpool import -F Universe
cannot mount ‘/Universe’: failed to create mountpoint: Read-only file system
Import was successful, but unable to mount some datasets
