BTW, with the stable version I decided to give it a try and using dockge worked well for me on adapting my ansible generated docker compose containers without any UI interaction.
There’s some small changes like having to create my own docker user and skipping the package management but then it works as long as I drop the compose files in the stacks dataset. Hopefully some day that will be supported by default, I definitely think the apps format will over time change a bit as it’s not necessary for it to be as convoluted anymore.
This is the thread that definitely saved my bacon. I was struggling to install the Linkwarden docker through the Truenas “Custom App” menu but Dockge definitely made it all happen exactly as intended.
@Stux, thanks a bunch for your very clear and concise video. Only thing I did against your advice was install Dockge with TrueNAS automatically creating the data sets for the Stacks and Data storage points. Figured I’d take a chance in the general release version of Electric Eel and it paid off.
I tried the same, I can successfully connect via the remote-ssh extension, but then in the docker extension it says “failed to connect”. Docker is running though, but I think the docker context is not setup correctly:
