Docker : Permission issue
Hello everyone,
Since the upgrade from k3s to docker, i like to test and install manually custom app to my truenas. But for some app keep have permission error (i try the id 0 568 or mine and even one i create for docker) but this keep causing permission error.
To precise, i create a dataset name docker to put everything inside. (so there is any change to do there ? )
For example deluge keep have this kind :
20:43:56 [ERROR ][deluge.config :510 ] Error moving new config file: [Errno 1] Operation not permitted: '/config/web.conf'
I have the same with nginx proxy manager when i want to create a certificate.
So if you have any solution or advice to do to not have this permission problem in the future.
Thank for your help
Luc
If it’s an NFSv4 acltype dataset, try setting the aclmode to passthrough.
AMEN, thank for your quick reply that work OMG ty (that was so dumb :frowning: )
