Running Dragonfish I have Dokuwiki running via Truecharts app. I am OK transferring all my other apps and settings to Electric Eel (Manually and automatic upgrade)
However the single blocker is Dokuwiki for which I’ve tried various YAML files (including the “official” one), and either they fail or don’t allow access to the config page etc on the designated ports
Does anyone have experience of success running dokuwiki on EE and able to provide tips. BW Tim
Hi, thanks (I was Naively thinking someone would say, Yeah I had this issue but this worked, but not to be maybe :-))
I used the “official” docker YAML
(Below)
# This is an example of a docker-compose file for DokuWiki. Familiarity with Docker and docker-compose is assumed.
# Adjust this to your needs before using.
services:
dokuwiki:
image: dokuwiki/dokuwiki:stable # other tags: master, <date> or <codename>
user: "1000:1000" # adjust to your required user id
restart: unless-stopped
ports:
- "8080:8080" # internal port is 8080, map to what you need
environment:
PHP_TIMEZONE: Europe/Berlin
#PHP_MEMORYLIMIT: 256M
#PHP_UPLOADLIMIT: 128M
volumes:
- ./storage:/storage
It “Seems” to run through without issue, but in the App list it immediately is marked stopped and starting fails…
This is the docker_logs.txt for today when I ran the YAML (no other apps installed)
BTW, this is on an HP microserver N45, essentially vanilla upgraded from Dragonfish progressively to EE 24.10.1 No other Apps (or anything apart from essential config). Running EE surprisingly well with 10Gb Ram, as a testbed server before upgrading my main TrueNAS server when I’ve learnt stuff
This was an incorrect statement, I had the host/container bit reversed
This part is not right, you need to modify the second half, the bit after the colon, to point to a valid place somewhere on one of your ZFS pools.
Here’s a modified example: - ./storage:/mnt/tank/dockerapps/dokuwiki
In this example my pool is named tank and I have created a sub-dataset named dockerapps and dokuwiki respectively, using the ordinary Dataset UI.
For it to fully work I would also need to make sure that the user the app runs as has the correct permissions or ACLs set to access the dokuwiki dataset.
Thanks again, I think I’ve done that, to no avail.
But I also found this in app_lifecycle.log
[2025/01/10 18:00:18] (ERROR) app_lifecycle.compose_action():56 - Failed 'up' action for 'dokuwiki' app: Network ix-dokuwiki_default Creating
Network ix-dokuwiki_default Created
Container dokuwiki Creating
Container dokuwiki Created
Container dokuwiki Starting
Error response from daemon: driver failed programming external connectivity on endpoint dokuwiki (719d4f25eb4c8904a86c97f741a38ef2f934ffe7b3c319c1632e2810513830f9): failed to bind port 0.0.0.0:443/tcp: Error starting userland proxy: listen tcp4 0.0.0.0:443: bind: address already in use
[2025/01/10 18:01:07] (ERROR) app_lifecycle.compose_action():56 - Failed 'up' action for 'dokuwiki' app: Network ix-dokuwiki_default Creating
Error response from daemon: driver failed programming external connectivity on endpoint dokuwiki (d4a8c59e10197f7c7725b68415b3d94c56e080686e530adfa99493a7e25e848e): failed to bind port 0.0.0.0:443/tcp: Error starting userland proxy: listen tcp4 0.0.0.0:443: bind: address already in use
Now… two things,
I don’t think it’s bound to 443 (though ?hangover from previous YAML version attempts not being removed?
I now note the dokuwiki instructions (for official docker install but not for other docker versions) make reference to a reverse proxy ??? (And at this point I can feel the water rising above my neck!)
Tried it both ways before!!! But tried again as your suggestion (having changed the permissions) and suddenly bingo
SO Now I have a blank/empty dokuwiki to play with and just have to check I can configure it (internally to dokuwiki) and add dokuwiki apps etc and I’m good to go
Many thanks will post in a few days confirming it works and details of process to achieve it to summarise/round off the thread for others benefits
Been there… just spend a week diagnosing why my truenas box didnt boot after a power outage. Didn’t even get a output on a monitor or a post… I thought t he motherboard was fried, so i ordered a new one, spend an afternoon rebuilding the box with a new motherboard, just to be greeted with the same error. Turns out that one of my m.2 ssds died and blocked the motherboard from detecting the gpu, which prevented a succesful post.
Replaced the ssd and it fired right up… now i have a spare motherboard laying around
In order to summarise the successful process (for me) in case others come a-searching…
Disclaimer
I can’t advise on setting permissions properly
I have no advice regarding configuring dokuwiki itself after install
Caveat emptor!!!
Aim: To install dokuwiki into a Docker container as at this time there is not an official TrueNAS Docker solution for Dokuwiki, and this was the final piece of the jigsaw for me to upgrading from Dragonfish to Electric Eel where I had Dokuwiki running from Truecharts
I used the “Official” Dokuwiki Docker YAML file from here
For me the only element I changed was the last line from
to
- /mnt/tank/data/dokuwikidata:/storage
where /mnt/tank/data/dokuwikidata is the path to the dataset I had created for this purpose. Your path will be different
The main issue I had, came down to permissions for this dataset, but once fixed dokuwiki came up nicely.
Because this was a vanilla server I got a blank dokuwiki , but when I redid things, creating a new dataset, and pasted the conf, data, lib folders from my other server into the dataset, and ran the YAML file afresh I got the old dokuwiki site back up again.
This may not be a complete guide but may help another complete idiot to at least get some way there
I was able to get a dokuwiki installed by following along with this thread using this config:
services:
dokuwiki:
user: "3002:3001" # adjust to your required user id
ports:
environment:
PHP_TIMEZONE: America/New_York
volumes:
- /mnt/LCARS/Applications/dokuwiki:/storage
And I can surf to it just fine, but I can’t find any admin tools for the site. Where are they located?
