Drive with 1 error
So, let me explain something here… Your failure being reported is a ZFS failure, not a hard drive failure.
While a hard drive failure can cause a ZFS failure, it often is not the case, it can be caused by the system crashing, a sudden reboot or power issue.
Two things:
  1. Run zpool clear tank to clear the error at hand.
  2. Run a SMART Long test on the correct drive. Once that completes you can post the output of the results. Or you could use what I provided earlier to diagnose if you have a problem.
  3. If the drive is faulty, then replace the drive. If the drive looks good, then keep an eye on it. If the same type of failure occurs on this one specific drive, it is time to troubleshoot and run another LONG test.
My strong advice, setup a daily Short test for all your drives. This is a simple 2 minute maximum test. And setup a weekly Long test for all your drives. Having 12TB drives (just over 18 hours to test a drive), I would recommend one drive a day, maybe Mon, Tue, Wed, Thu, Fri for example. I would run the Short tests at say 2200 (10pm) and then run a Long test at 2215 (10:15pm). This is an easy setup, and just an example. Change the dates/times to whatever works for you.
How would that impact your system? With the RAIDZ2, it should not impact your system at all. SMART tests always are the lowest priority so any data requests are bumped to the top and fulfilled. When the drive is idle, the testing resumes. Spreading your the Long tests reduces heat build up as well, especially if you have the drives next to each other with very little gap for air.
hi hi
Interesting that you saying this is ZFS not the physical drive, how would that then be localised to just the one drive ?
The original log was a short run… on the wrong drive… which i picked up when i ran the long check last night… and used beyond compare this morning, file side by side… sorry…
I currently have 3 pools, so I stagger short test during the week, I don’t normally run the long test.
I already have a replacement drive on the way, not sure how much stress I want to put on this drive… if it might be the cause of the problems, as it’s only being reported on it…
My worry atm is ye, RaidZ2 is saving my @ss atm… as long as this drive is ok, and there is not another drive with problems, as I replaced all 5 drives from the same supplier.
G
with me having run the pool command it kicked off a resilver…
will leave that to complete and then do a new long test once completed.
G
ZFS is the format in which the data is written. There was some sort of data corruption caused by possibly a system crash (it happens). And then localized to a single drive is dependant on where in the write process the system is. I’ve seen 1, 2, + drives with a ZFS corruption. The key indicators are the ZPOOL results and if you have no drive failure indicators. So far you have not shown a single drive failure indicator.
‘SCRUB Failure != SMART Failure’ (!= not equal)
That is a mistake in my opinion. You should be running Long tests as well. The Short test just verifies a few locations on the drive and the drive electronics are working. The Long test reads all the sectors on the drive, meaning anyplace you would put data. However, I will not force the issue, only you know how you want to run your system and how far in advance of a hard drive failure you would like to be warned.
I don’t understand. You typed the command I provided above and it kicked off a resilver?
Hope the Long test you run comes back with no errors. You now have the tools to decipher if a drive is throwing errors on not.
understood, will put a standard schedule in place. think with my plan to collapse the 2 disk pool into one wider will also make this easier.
going to grow the 5x Raid2z to a 10 drive… and remove the bunker disk pool.
will then see how long a long test takes and basically move drive to drive, and cycle through the set…
yes…
the drive itself was showing totally faulted.
will kick off a long test on the drive tonight again and advise.
G
A long test for the 12TB drive will take 1085 minutes (~18 hours 6 minutes), longer if the drive is doing something such as routine NAS work. If you can, kick off the Long test as soon as the resilver has completed.
Resilver done, kicking off… chat tomorrow afternoon :wink:
G
Strange.
The Long test fails as per below.
But the Window view does not show a degraded disk pool, non of the drives are showing errors.
Long test output.
sde2.txt (26.3 KB)
sde2.txt
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.29-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf Pro
Device Model:     ST12000NE0008-2PK103
Serial Number:    ZTN08BQ7
LU WWN Device Id: 5 000c50 0c30b7df0
Firmware Version: CN03
User Capacity:    12,000,138,625,024 bytes [12.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Nov  9 20:06:42 2024 SAST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
Self-test execution status:      ( 121)	The previous self-test completed having
					the read element of the test failed.
data collection: 		(  575) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 (1086) minutes.
Conveyance self-test routine
recommended polling time: 	 (   2) minutes.
SCT capabilities: 	       (0x50bd)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   081   064   044    -    117578840
  3 Spin_Up_Time            PO----   089   089   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    8
  5 Reallocated_Sector_Ct   PO--CK   094   094   010    -    23176
  7 Seek_Error_Rate         POSR--   076   060   045    -    40120844
  9 Power_On_Hours          -O--CK   100   100   000    -    195
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    8
187 Reported_Uncorrect      -O--CK   081   081   000    -    19
188 Command_Timeout         -O--CK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   052   038   040    Past 48 (Min/Max 41/50 #35)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    11
193 Load_Cycle_Count        -O--CK   100   100   000    -    12
194 Temperature_Celsius     -O---K   048   062   000    -    48 (0 28 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-   016   001   000    -    117578840
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
200 Pressure_Limit          PO---K   100   100   001    -    0
240 Head_Flying_Hours       ------   100   253   000    -    194h+24m+37.313s
241 Total_LBAs_Written      ------   100   253   000    -    6485418040
242 Total_LBAs_Read         ------   100   253   000    -    8285439068
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   2048  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    768  Current Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS      24  Device vendor specific log
0xa2       GPL     VS   16320  Device vendor specific log
0xa4       GPL,SL  VS     160  Device vendor specific log
0xa6       GPL     VS     192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xad       GPL     VS      16  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc1       GPL,SL  VS       8  Device vendor specific log
0xc3       GPL,SL  VS      32  Device vendor specific log
0xc9       GPL,SL  VS       8  Device vendor specific log
0xca       GPL,SL  VS      16  Device vendor specific log
0xd1       GPL     VS     336  Device vendor specific log
0xd2       GPL     VS   10000  Device vendor specific log
0xd4       GPL     VS    2048  Device vendor specific log
0xda       GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
Device Error Count: 19
	CR     = Command Register
	FEATR  = Features Register
	COUNT  = Count (was: Sector Count) Register
	LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
	LH     = LBA High (was: Cylinder High) Register    ]   LBA
	LM     = LBA Mid (was: Cylinder Low) Register      ] Register
	LL     = LBA Low (was: Sector Number) Register     ]
	DV     = Device (was: Device/Head) Register
	DC     = Device Control Register
	ER     = Error register
	ST     = Status register
Error 19 [18] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
  When the command that caused the error occurred, the device was doing SMART Offline or Self-test.
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 00 6d dd fa 00 00 00  Error: UNC at LBA = 0x6dddfa00 = 1843264000
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 00 00 00 10 00 00 00 00 12 10 40 00     19:47:18.225  READ FPDMA QUEUED
  60 00 00 00 58 00 01 8c ba 61 90 40 00     19:47:14.239  READ FPDMA QUEUED
  61 00 00 00 58 00 03 08 74 7e 00 40 00     19:47:14.238  WRITE FPDMA QUEUED
  60 00 00 00 a8 00 00 6d dc d8 90 40 00     19:47:14.238  READ FPDMA QUEUED
  60 00 00 00 58 00 00 6d dd f9 58 40 00     19:47:14.238  READ FPDMA QUEUED
Error 18 [17] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
  40 -- 51 00 00 00 00 6d dd f8 80 00 00  Error: UNC at LBA = 0x6dddf880 = 1843263616
  60 00 00 00 58 00 00 6d dd f7 a8 40 00     19:47:04.974  READ FPDMA QUEUED
  60 00 00 00 58 00 00 6d dd f9 58 40 00     19:47:04.974  READ FPDMA QUEUED
  60 00 00 00 50 00 00 6d 56 cc f8 40 00     19:47:04.974  READ FPDMA QUEUED
  60 00 00 00 58 00 00 6d 56 cc 48 40 00     19:47:04.974  READ FPDMA QUEUED
  60 00 00 00 58 00 00 6d 56 c4 30 40 00     19:47:04.974  READ FPDMA QUEUED
Error 17 [16] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
  40 -- 51 00 00 00 00 6d de 6e 50 00 00  Error: WP at LBA = 0x6dde6e50 = 1843293776
  61 00 00 00 08 00 02 68 84 39 30 40 00     19:46:47.109  WRITE FPDMA QUEUED
  61 00 00 00 58 00 00 6d de 69 10 40 00     19:46:47.108  WRITE FPDMA QUEUED
  60 00 00 00 10 00 05 74 ff fc 10 40 00     19:46:47.108  READ FPDMA QUEUED
  60 00 00 00 10 00 05 74 ff fa 10 40 00     19:46:47.108  READ FPDMA QUEUED
  60 00 00 00 10 00 00 00 00 12 10 40 00     19:46:47.108  READ FPDMA QUEUED
Error 16 [15] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
  40 -- 51 00 00 00 00 6d de 6c 98 00 00  Error: WP at LBA = 0x6dde6c98 = 1843293336
  61 00 00 00 10 00 05 74 ff fc 10 40 00     19:46:37.868  WRITE FPDMA QUEUED
  61 00 00 00 10 00 05 74 ff fa 10 40 00     19:46:37.868  WRITE FPDMA QUEUED
  61 00 00 00 10 00 00 00 00 12 10 40 00     19:46:37.868  WRITE FPDMA QUEUED
  61 00 00 00 08 00 05 74 ff fd 78 40 00     19:46:37.867  WRITE FPDMA QUEUED
  61 00 00 00 08 00 05 74 ff fb 78 40 00     19:46:37.787  WRITE FPDMA QUEUED
Error 15 [14] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
  40 -- 51 00 00 00 00 6d de 69 58 00 00  Error: WP at LBA = 0x6dde6958 = 1843292504
  61 00 00 00 28 00 03 25 33 fa 38 40 00     19:46:32.347  WRITE FPDMA QUEUED
  61 00 00 00 28 00 03 1d 35 d7 88 40 00     19:46:32.347  WRITE FPDMA QUEUED
  61 00 00 00 08 00 03 08 74 7c 98 40 00     19:46:32.347  WRITE FPDMA QUEUED
  61 00 00 00 28 00 02 69 61 a6 e8 40 00     19:46:32.347  WRITE FPDMA QUEUED
  61 00 00 00 10 00 02 68 f6 f7 60 40 00     19:46:32.347  WRITE FPDMA QUEUED
Error 14 [13] occurred at disk power-on lifetime: 87 hours (3 days + 15 hours)
  40 -- 51 00 00 00 00 05 56 20 d0 00 00  Error: UNC at LBA = 0x055620d0 = 89530576
  60 00 00 05 68 00 00 05 56 20 48 40 00     16:37:19.718  READ FPDMA QUEUED
  61 00 00 00 58 00 00 05 56 15 28 40 00     16:37:14.813  WRITE FPDMA QUEUED
  61 00 00 00 b0 00 00 05 56 10 c0 40 00     16:37:14.813  WRITE FPDMA QUEUED
  61 00 00 02 58 00 00 05 56 15 80 40 00     16:37:14.812  WRITE FPDMA QUEUED
  61 00 00 03 b8 00 00 05 56 11 70 40 00     16:37:14.811  WRITE FPDMA QUEUED
Error 13 [12] occurred at disk power-on lifetime: 87 hours (3 days + 15 hours)
  40 -- 51 00 00 00 00 05 56 11 40 00 00  Error: UNC at LBA = 0x05561140 = 89526592
  60 00 00 07 c8 00 00 05 56 10 c0 40 00     16:37:05.477  READ FPDMA QUEUED
  60 00 00 07 c0 00 00 05 56 09 00 40 00     16:37:02.841  READ FPDMA QUEUED
  61 00 00 05 68 00 00 05 55 f9 78 40 00     16:36:57.073  WRITE FPDMA QUEUED
  61 00 00 00 58 00 00 05 55 ff 38 40 00     16:36:57.073  WRITE FPDMA QUEUED
  61 00 00 00 58 00 00 05 55 fe e0 40 00     16:36:57.073  WRITE FPDMA QUEUED
Error 12 [11] occurred at disk power-on lifetime: 87 hours (3 days + 15 hours)
  40 -- 51 00 00 00 00 05 55 fe c8 00 00  Error: WP at LBA = 0x0555fec8 = 89521864
  61 00 00 02 08 00 00 05 55 f1 b8 40 00     16:36:47.764  WRITE FPDMA QUEUED
  61 00 00 00 50 00 00 05 55 f7 20 40 00     16:36:47.764  WRITE FPDMA QUEUED
  61 00 00 03 60 00 00 05 55 f3 c0 40 00     16:36:47.763  WRITE FPDMA QUEUED
  61 00 00 01 60 00 00 05 55 f7 70 40 00     16:36:47.762  WRITE FPDMA QUEUED
  61 00 00 00 50 00 00 05 55 f8 d0 40 00     16:36:47.761  WRITE FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed: read failure       90%       195         941344
# 2  Extended offline    Completed: read failure       90%       194         941344
# 3  Extended offline    Completed without error       00%       182         -
# 4  Short offline       Completed without error       00%       151         -
# 5  Extended offline    Completed: read failure       90%        92         941344
# 6  Extended offline    Completed: read failure       90%        91         941360
# 7  Short offline       Completed without error       00%        79         -
2 of 4 failed self-tests are outdated by newer successful extended offline self-test # 3
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    48 Celsius
Power Cycle Min/Max Temperature:     41/50 Celsius
Lifetime    Min/Max Temperature:     27/62 Celsius
Under/Over Temperature Limit Count:   0/37
SCT Temperature History Version:     2
Temperature Sampling Period:         3 minutes
Temperature Logging Interval:        59 minutes
Min/Max recommended Temperature:     10/40 Celsius
Min/Max Temperature Limit:            5/60 Celsius
Temperature History Size (Index):    128 (83)
Index    Estimated Time   Temperature Celsius
  84    2024-11-04 14:35    42  ***********************
  85    2024-11-04 15:34    42  ***********************
  86    2024-11-04 16:33    42  ***********************
  87    2024-11-04 17:32    41  **********************
  88    2024-11-04 18:31    42  ***********************
  89    2024-11-04 19:30    43  ************************
 ...    ..(  5 skipped).    ..  ************************
  95    2024-11-05 01:24    43  ************************
  96    2024-11-05 02:23    42  ***********************
 ...    ..(  2 skipped).    ..  ***********************
  99    2024-11-05 05:20    42  ***********************
 100    2024-11-05 06:19    45  **************************
 ...    ..(  2 skipped).    ..  **************************
 103    2024-11-05 09:16    45  **************************
 104    2024-11-05 10:15    43  ************************
 107    2024-11-05 13:12    43  ************************
 108    2024-11-05 14:11    44  *************************
 ...    ..(  3 skipped).    ..  *************************
 112    2024-11-05 18:07    44  *************************
 113    2024-11-05 19:06    43  ************************
 ...    ..(  4 skipped).    ..  ************************
 118    2024-11-06 00:01    43  ************************
 119    2024-11-06 01:00    44  *************************
 120    2024-11-06 01:59    44  *************************
 121    2024-11-06 02:58    43  ************************
 122    2024-11-06 03:57    43  ************************
 123    2024-11-06 04:56    45  **************************
 124    2024-11-06 05:55    47  ****************************
 125    2024-11-06 06:54    46  ***************************
 126    2024-11-06 07:53    45  **************************
 127    2024-11-06 08:52    44  *************************
   2    2024-11-06 11:49    44  *************************
   3    2024-11-06 12:48    43  ************************
   4    2024-11-06 13:47    43  ************************
   5    2024-11-06 14:46    44  *************************
   6    2024-11-06 15:45    43  ************************
  11    2024-11-06 20:40    43  ************************
  12    2024-11-06 21:39    42  ***********************
  16    2024-11-07 01:35    42  ***********************
  17    2024-11-07 02:34    43  ************************
  18    2024-11-07 03:33    43  ************************
  19    2024-11-07 04:32    45  **************************
  20    2024-11-07 05:31    46  ***************************
  21    2024-11-07 06:30    47  ****************************
  22    2024-11-07 07:29    46  ***************************
  23    2024-11-07 08:28    46  ***************************
  24    2024-11-07 09:27    46  ***************************
  25    2024-11-07 10:26    45  **************************
  26    2024-11-07 11:25    45  **************************
  27    2024-11-07 12:24    45  **************************
  28    2024-11-07 13:23     ?  -
  29    2024-11-07 14:22    44  *************************
  30    2024-11-07 15:21    46  ***************************
  31    2024-11-07 16:20    45  **************************
  34    2024-11-07 19:17    45  **************************
  35    2024-11-07 20:16    44  *************************
  36    2024-11-07 21:15    44  *************************
  37    2024-11-07 22:14    45  **************************
  38    2024-11-07 23:13    44  *************************
  42    2024-11-08 03:09    44  *************************
  43    2024-11-08 04:08    45  **************************
  44    2024-11-08 05:07    44  *************************
  45    2024-11-08 06:06    44  *************************
  46    2024-11-08 07:05     ?  -
  47    2024-11-08 08:04    41  **********************
  48    2024-11-08 09:03    47  ****************************
  49    2024-11-08 10:02    48  *****************************
 ...    ..(  2 skipped).    ..  *****************************
  52    2024-11-08 12:59    48  *****************************
  53    2024-11-08 13:58    47  ****************************
 ...    ..(  3 skipped).    ..  ****************************
  57    2024-11-08 17:54    47  ****************************
  58    2024-11-08 18:53    48  *****************************
  59    2024-11-08 19:52    48  *****************************
  60    2024-11-08 20:51    49  ******************************
  61    2024-11-08 21:50    49  ******************************
  62    2024-11-08 22:49    48  *****************************
  63    2024-11-08 23:48    47  ****************************
  67    2024-11-09 03:44    47  ****************************
  68    2024-11-09 04:43    48  *****************************
  69    2024-11-09 05:42    47  ****************************
  70    2024-11-09 06:41    48  *****************************
 ...    ..(  3 skipped).    ..  *****************************
  74    2024-11-09 10:37    48  *****************************
  75    2024-11-09 11:36    49  ******************************
  76    2024-11-09 12:35    48  *****************************
  77    2024-11-09 13:34    49  ******************************
  78    2024-11-09 14:33    49  ******************************
  79    2024-11-09 15:32    48  *****************************
  83    2024-11-09 19:28    48  *****************************
SCT Error Recovery Control:
           Read:    100 (10.0 seconds)
          Write:    100 (10.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4               8  ---  Lifetime Power-On Resets
0x01  0x010  4             195  ---  Power-on Hours
0x01  0x018  6      6485091248  ---  Logical Sectors Written
0x01  0x020  6        27904277  ---  Number of Write Commands
0x01  0x028  6      8285384368  ---  Logical Sectors Read
0x01  0x030  6        34684064  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4             194  ---  Spindle Motor Power-on Hours
0x03  0x010  4             194  ---  Head Flying Hours
0x03  0x018  4              12  ---  Head Load Events
0x03  0x020  4           23176  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4              11  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              48  ---  Current Temperature
0x05  0x010  1              47  ---  Average Short Term Temperature
0x05  0x018  1               -  ---  Average Long Term Temperature
0x05  0x020  1              62  ---  Highest Temperature
0x05  0x028  1               0  ---  Lowest Temperature
0x05  0x030  1              56  ---  Highest Average Short Term Temperature
0x05  0x038  1              42  ---  Lowest Average Short Term Temperature
0x05  0x040  1               -  ---  Highest Average Long Term Temperature
0x05  0x048  1               -  ---  Lowest Average Long Term Temperature
0x05  0x050  4              96  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4              30  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4              16  ---  Number of Hardware Resets
0x06  0x010  4               8  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
0xff  0x008  7               0  ---  Vendor Specific
0xff  0x018  7               0  ---  Vendor Specific
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            2  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
Seagate FARM log (GP Log 0xa6) supported [try: -l farm]
Yes, that drive is toast. So this was the first actual drive failure notification you received.
This is very odd to fail a Long test with so few hours, but it proves Infant Mortality still exists and the reason everyone should perform some sort of burn-in test.
This wasn’t a refurbished drive was it? I doubt it, I checked the warranty and it looks good.
I am in discussion with the supplier to have it replaced.
ye… wondering if this is a previously used drive that some how got reset and repackaged…
Will advise
G
If you haven’t already, run a Long test on your other drives. Remember, this is the lowest priority so any transactions you need the NAS to do, it will happen without delay. But if you have the drives packed tightly together where they could build up heat, don’t test adjacent drives to limit the heat buildup. But if you have proper cooling, that will not be an issue.
Good luck with your vendor.
will start testing, going to do them one by one… just to take it easy…
G
Been wondering…
if i take the problem drive offline, can I run the bad blocks on the TrueNAS itself?
G
Yes. Of course, this will degrade the pool, and badblocks still needs to be run in a tmux session.
I’d argue that there is no point in doing so as the smart failure is already clear & immediate RMA territory. All badblocks will do is delay this by apprx a week while you wait for it to finish.
are we saying this drive is a paper weight, or is there a way to mark the bad blocks and use the balance…?
G
The drive is not a paperweight, you should RMA it.
I’m saying that it should be rma’d asap. I wouldn’t personally bother marking anything at all because it is a failed product that is under warranty & should either be returned per merchant agreement for a like for like replacement, or open an RMA with Seagate to get a placement as drive is showing in warranty until 2026.
Either way should get you a working drive instead of a degraded/paper weight drive.
I’ve personally ordered a replacement from another vendor.
Waiting on this merchant to replace this drive.
G
