- select a dataset
- at Permissions select Edit
- Add Item select group and groiup name
- (there is no save so I assume it is saved automatically?)
- navigate back
The selected Permissions are no longer there.
I’m sure there is a save button. Post a screenshot please.
I feel like there is something lower in that screenshot that you have perhaps accidentally missed.
I think maybe you are not scrolling down within the browser.
There is a save ACL button just below Add Item. Also if you are modifying the Owner or Owner Group, make sure you select the Apply checkboxes before saving.
If you can’t use the scrollbar on the right side in that screenshot, try a different browser.
