EFAULT Docker service not running
A few things happened which resulted in me deleting the ix-apps datasets.
fast forward to now docker isn’t running and I’m lost on how to fix it.
have you tried unsetting and resetting the apps pool? that should stop the docker service and on resetting the pool start the apps service and re-create the .ix-apps dataset.
did not, that fixed the docker problem
but now I get a hefty error talking bout some [EFAULT] Failed to render compose templates: Traceback
Trying to Reinstall plex
can you post a screenshot of the whole error message?
The actual error is often discribed in the last sentence of that error message…
Thank you, made me look at the root of the problem and it was a simple fix
