[EFAULT] Unable to determine default interface
Hello, I am working with TrueNAS SCALE Electricl Eel.
On configuring Apps, when adding a pool, I get the error:
Failed to configure docker for Applications: Unable to determine default interface
Also, when selecting the System > Update, I receive an error
TrueNAS was unable to reach update servers.
Is this because I have two networks attached?
Disregard, seems I missed setting up global network properties and assigning a default gateway.
I also had this issue… strange… on another TrueNAS I have I did not have to set the default gateway (they are both set to get this stuff via DHCP actually)… anyways did you have to reboot it to take this assignment of a default GW in effect?
I had the same issue last night and this morning with mine, and mine is also setup for DHCP. I then realized that it coincided with me having power, and therefore internet outage, at home, and so my TrueNAS would come up before the router & internet connection. This happened twice, evening and morning, so my assumption is that the NAS doesn’t receive it’s DHCP from the router because the router wasn’t up yet, and so gave the docker interface error. But when the router & internet eventually did come up and it did get a reserved DHCP address, I was able to access the TrueNAS, but the app’s section was still “broken” with that error, and only resolved itself after I rebooted TrueNAS. Then everything came up working properly again.
My 2 cents.
I’m having the same issue after multiple restarts. It worked successfully after upgrading from dragonfish to electric eel, but now every time I restart i get the same error " Failed to configure docker for Applications: Unable to determine default interface". I’m not having network issues. There isn’t a setting anymore to set the interface like there was with Kubernetes. I have 2 dual port nics in a dell poweredge server.
Does anyone have any advice on how to set a default interface?
I also got the lovely “Failed to configure docker for Applications: Unable to determine default interface”
Fix was to sort out the Network > Global configuration settings and reboot.
I encountered the same error Failed to configure docker for Applications: Unable to determine default interface after changing the router my truenas was connected to, which also changed the NAT hairpinning address scheme.
As TrueAmateur notes, checking the settings under Network > Global Configuration (e.g. nameserver & default gateway) may help resolve this. You may also want to check if your router reset itself after a power-outage event.
Just want to add here, I also ran into this problem after switching to a new router/network. The fix was to clear the default gateway in global configuration as mentioned here.
I’m pretty sure I didn’t set these fields, so maybe there’s a bug in TrueNAS?
Hi
I am also getting this error, I tried to reset the gateway but it did not work. What is the right setting to change ?
I delete the global gateway (IPv4 Default Gateway) and reboot TrueNas. I am using DHCP.
Critical
2025-10-26 21:19:40 (America/Los_Angeles)
Dismiss
Go to App Settings
perhaps there is bug somewhere, the following command can be executed to temporarily solve the problem, but it will appear again after restarting the machine
midclt call service.control START docker
Same issue for me when changing to a static IP address, but all working after a reboot.
I had this same issue after switching to a new router. I was able to fix it by resetting the the IPv4 gateway address (as previous commenters mentioned) AND deleting the IPv6 address. I kept getting an “invalid address“ error before realizing it was talking about the IPv6 address from my old router.
Specifically, my old router used a 10.0.0.1 address for the gateway and my new router uses 192.168.1.1. The old 10.0.0.1 address was saved in my global network settings from the old router and changing it to 192.168.1.1 fixed the issue.
