eGPU passthrough for LLM hosting
Hi All:
I’m new to this forum so apologizes upfront if the topic has already been addressed.
Currently running Dragonfish-24.04.2 (upgrading soon to ElectricEel and beyond). I have modest 9 yr old hardware that has served me well due to the ix-systems development prowess and vision. Kudos!
I’m curious to learn of any experiences around using an Oculink connected eGPU for pass-through to apps/VMs. My use case would be to host a local LLM.
I realize I’ll likely need to upgrade the hardware. But, I would be remiss if I went down that rabbit hole without asking for insight from anyone who’s already jumped into the deep end :grinning:
Feedback would be appreciated.
Thanks!
I’ve never tried it. I just threw a low-profile Arc gpu in a slot for not-LLM reasons.
I’m not sure if you’re asking if it’s possible or if it’ll work well. It should be possible. Whether it will work well depends on the card and oculink bandwidth, but I’d expect a noticeable impact over PCIe.
Welcome to the forum
Thanks Jorsher,
My real interest is in understanding if the gpu will be picked up in Truenas over a M2. to oculink interface. I realize there will be a performance hit. But, I would imagine it will be negligible for an LLM application.
Best Regards!
M.2 is usually PCIe. OcuLink is PCIe. It should be seen more or less the same as connecting the card to a PCIe slot. Using the M.2 could further reduce the bandwidth to the GPU.
I don’t do ML training, but from what I understand the more VRAM and training data, the better. The limited bandwidth could negatively impact ML more than gaming.
I currently have a similar setup on a mini PC. Its connected to an eGPU via M.2 Oculink. Using Windows’ WSL, Ollama, OpenWebUI and a 12GB NVIDIA 3060 series card. I’ve been able to get pretty good performance on 7b to 14b models. The goal here is to have a self hosted LLM service, on the home network, that I can use in conjunction with VS Code and maybe home assistant (and their upcoming voice assistant).
In any event, its something I can play with to keep me out of trouble :smirk:
Regards,
So it took me a while, but I finally pulled the trigger on a Minisforum N5 NAS. It has a fresh, bear metal, install of Truenas Scale Goldeye, However, after some tinkering I’m still having trouble getting Scale to recognize an NVIDIA RTX 3060 that’s connected via Oculink. I’m using a Minsforum DEG1 Dock to host the RTX. The same rig running on another misforum mini PC works just fine.
My understanding was that the Goldeye includes support for 3000 series cards. However, an lspci from the shell only returns the AMD/ATI embedded GPU. The goal is to serve Ollama and Open WEBUI from the box. Any direction would be appreciated.
Hey, @Martin_Mateo
I’m currently going down a similar rabbit hole. My idea is to use a Minisforum ms-01 (running TrueNAS 25.10.2.1) and buy a DEG2 eGPU enclosure to use over OCuLink, and hook up an RTX 4090 I already have on an unused pc.
What I’m trying to figure out is:
Can TrueNAS pass through and use the eGPU only when running LLM workloads?
And then basically leave it idle (or low power) the rest of the time?
I want to avoid the GPU drawing a lots of power 24/7 and only “spin it up” when I actually need model stuff.
Curious if you managed something . Cheers jmac
I’m currently going down a similar rabbit hole. My idea is to use my current Minisforum ms-01 (running TrueNAS 25.10.2.1) and buy a DEG2 eGPU enclosure to use over OCuLink, and hook up an RTX 4090 I already have on an unused pc.
Hi jmac:
I’m happy to report that my struggles where due to a user issue. I have multiple oculink cables and initially don’t use the one that came with the dock. Once I did, lspci listed my 3060. Currently running OLLAMA and openwebui. Also installed searxing and configured openwebui to use it for web searches. As for power, I don’t have a killawatt meter to test consumption. But after a couple of months, I really haven’t seen a significant increase in my electric bill. When not in use, the card is in idle.
Best of luck!
