Electric Eel Homebridge app not working
Before moving to 24.10 about 2 months ago homebridge was working on bluefin with the docker create app button in the ui. I figured once I moved over that I wouldn’t have an issue getting it working again. I can get the app up and running with no problem with my old back up and with a new setup, however I can’t get anything to add to HomeKit. I think it has to do with networking since it’s only picking up the 172.x.x.x network. Has anyone run into this and have a solution. I was thinking that creating a bridge might help, but every time I go to create one it never actually creates it. Thanks for any and all advice in advance!
Edit: I forgot to add that I have used the Dockge app, the truenas IX app in the discover apps section, and the custom app all with the same result.
It sounds like there may not be a lot of folks running homebridge on EE yet, but I just ran into this same problem. The main issue stems from homebridge needing to run on the host network since macvlan or static ip’s aren’t available yet for the docker stack on EE. I could get the UI to run if I didn’t use host network, but then none of the devices in home bridge would show up or would show as not responding in the home app. It looks like 5353 mdns isn’t forwarding through for network discovery without using a static IP or using the host. The issue with making homebridge run on the host network is a conflict for mDNS for truenas itself. Truenas uses mdns to broadcast in finder and explorer as a network device. if you go to network and then settings in truenas, you can turn off mdns and then run homebridge on the host network until static IP’s or macvlan is enabled in a future update to Truenas Scale. I know its not optimal and is a workaround, but it worked for me and at least allows me to control my iot devices in the home app now which is more valuable than truenas using mdns.
If you tried a custom app, then you can do anything, including, using your own different IP. You can use cli to make networks too. Just depends how comfortable you are.
I tried that using a compose.yaml file and putting it as a custom app, tried it in portainer and tried it using dockge and couldn’t get it to bind fully. Have you tried doing it with RC2? A little about my network config on the truenas box: I only have 1 ethernet connected, set up as a bridge network with a static ip. I’m not able to get any inbound traffic to work on custom networks with any of the above mentioned solutions. Any other thoughts?
It’s just docker stuff, same as any other docker system. I did have one app that was using it on Eel with a bridge, yes, but then I went another way and I don’t have the old compose file. I switched desktops in the meantime and just don’t have it sadly.
So, the only thing I can tell you is, with compose, you can do it. Doubtful you can with the ix app to create custom apps, you’ll need your own compose file.
So I tried the custom app and I tried compose with dockge and here is my yaml file below. I want it to be on 192.168.1.251:8581. The crazy thing is whenever I do set it to the static ip I can get the container to start but I can’t get the ui to come up on that ip:port. Also when I do set it this way it makes my network go crazy forcing my unifi router to reset. I made sure that it’s an unused ip address and everything.
version: “3.8”
services:
homebridge:
image: homebridge/homebridge:latest
environment:
- PUID=568
- PGID=568
restart: always
#network_mode: bridge
volumes:
- /xxx/xxxx/xxxxx/xxxxxxxx:/homebridge
logging:
driver: json-file
options:
max-size: 10mb
max-file: “1”
ports:
- 8581:8581
networks:
custom_net:
ipv4_address: 192.168.1.251
networks:
custom_net:
driver: bridge
ipam:
- subnet: 192.168.0.0/16
gateway: 192.168.1.1
Well I use Time Machine for backing up all of our devices and mdns is required for that. So turning that off would be a no-go for us. Wife runs her business with a couple of them and need to have her backups as up to date as possible.
The Yaml file looks very similar to what I was trying to make work. I eventually did get it to respond/connect with a static ip and do some nslookups and pings in the terminal for the container using a custom macvlan network instead of bridging, but was unable to access the UI or ping the container from any outside sources. The only way I’ve been able to make it work was to attach it to the host and then disable mDNS on the TrueNAS itself.
Fingers crossed someone else comes up with a solution before having to wait for IX Systems to make the UI able to configure bridge and macvlan networks. Unfortunately Homebridge and several other containers that require host or static ip’s won’t work fully until this is an option.
Dang! So much for all of your current apps will work with the new version! I just don’t see why it worked perfectly fine with docker on dragonfish with jailmaker AND with the custom app where it pulled the docker image.
As I said I don’t remember and I don’t have a reason to try it again. I’m curious about a few things without spending time to create one, why is your subnet setting 192.168.0.0/16? Seems wrong. And the network you created, did you attach it to br0 or eth#? I believe it had to be on the bridge (br0). Did you add the custom IP as an alias to the bridge?
This is what I have it to now but still can’t get the UI to come up. Keeps saying npm error request to https://registry.npmjs.org/homebridge failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org. In the logs it shows the 192.168.1.135 as net0 and joining the mDNS on that same ip.
EDIT: it’s net0 not eth0. The 172.xxx.xxx.xxx address shows as eth0.
services:
  homebridge:
    environment:
      - PUID=568 #CHANGE_TO_YOUR_UID
      - PGID=568 #CHANGE_TO_YOUR_GID
      - TZ=America/New_York
    restart: always
    volumes:
      - /mnt/xx/xx/xx:/homebridge
    logging:
      driver: json-file
      options:
        max-size: 10mb
        max-file: "1"
    ports:
      - 8581:8581
    networks:
      custom_net:
        ipv4_address: 192.168.1.135
networks:
  custom_net:
    driver: bridge
    ipam:
        - subnet: 192.168.1.0/24
Same issue here.
I upgraded to EE yesterday. Other Apps are easy to deploy where only a few changes are needed. But I can’t get HomeBridge to run.
Like you said, HomeBridge requires connection to the home network.
If you choose host network, port forwarding cannot be configured. And default Web UI on port 8581 won’t open.
I tried to not choose host network and map 8581 to another port (in my case 10081) then I can access Web UI.
In this situation, HomeBridge has access to Internet and Plugins can be upgraded normally. But the Settings of HomeBridge shows that the App only listens to 172.X.X.X interface, which makes it impossible to connect to IOT devices in the home network. Mapping HomeBridge service port 51354 to host network doesn’t help either.
I think this issue is related to the new way of configuring Apps that comes with Electric Eel because users cannot choose network interface for the App anymore. As a result, HomeBridge either fails to listen to the correct interface or there is no access to Web UI.
I do hope that they will acknowledge the issue and give some type of solution or workaround before EE actually launches seeing as this is something most people will run into if they run apps that need external access. Would hate to have to get another computer to run homebridge. Having a similar issue with other apps as well that worked fine before the update
I don’t see any related bug tickets in our queue for Homebridge. If you believe there is a bug in the app, then we need it a bug report in order to alert our engineers to investigate it. You can use the Report a Bug link at the top of any forum page to link over to Jira and submit a report.
It’s not necessarily a bug with homebridge or any other app with these issues. It seems to be related to how the docker containers do external networking. I can’t use host network without issue
In that case maybe a Feature Request, if there isn’t already one there that covers your desired use case.
This is a spot on description of the problem. Under Dragonfish the option exists to add an external interface to the container. This is what you need so that it can connect directly to your home network as it’s required by Homebridge to be able to talk to your IoT devices. Until a similar configuration is added to Electic Eel, you will not be able to install and run Homebridge on EE. I have had to revert to Dragonfish for now and will have to stick there until this gets added to EE’s container creation options, or I migrate to a different platform for Homebridge and/or my NAS.
Yeah whats crazy is I have Home Assistant OS on a VM and I have the HomeKit integration installed on there and all of the devices show up and work perfectly. So about a month or so ago I tried to start up a VM for homebridge and the same problem. I wonder what it is with homebridge
I went ahead and created the feature request since it seems like there are several of us who run Homebridge as an app on TrueNAS and are affected by this.
This is not a TN issue, but operator lack of knowledge/experience.
“ipv4_address: 192.168.1.251”
You can try to put an IP-address on anything, but if the interface is NOT on that network that you want, it will do nothing.
People need to learn how Docker networking works.
The default bridge uses NAT, which should work for most apps/services that “reach out”, but not for anything that cannot be reverse-proxied or the ones that are “servers” and need to hear multicast and broadcast packets.
If you DO need full network capabilities, you need either network_mode host or macvlan.
The Homebridge instructions for Docker installation does have:
network_mode: host
Also, TN EE DOES have an option for the Catalog Apps to use the Host Network!
(Does not have the option for Macvlan network, but that can be done in docker compose, if you really need it).
