Electric Eel -> ix-applications
Is the ix-applications dataset still being used by Electric Eel?
Afaik it now uses the hidden “.ix-apps” dataset now so it can be removed?
Yep, it is kept there in part at least because some may be using the storage on it, so, once you have converted all your apps, etc., you can delete it.
If you’re happy with the transitioned apps and have no plans to revert back to a pre-EE-install, it serves no purpose.
