Trying to install Nextcloud on Truenas-scale. The image for the Nextcloud app seems to be missing.
[ENOENT] Unable to locate 'nextcloud' versions
I backed up the config and then removed and reinstalled the Truenas VM and restored the config but that did not help.
Is there a way I can reinstall the image for nextcloud? I am guessing this can be done with Apps/manage-container-images/Pull Image but I would need the Image name as registry/repo/image
here is my Manage Container Images screen
And here is the “More info…” for the error above.
File "/usr/lib/python3/dist-packages/middlewared/plugins/catalog/apps_util.py", line 115, in retrieve_cached_versions_data
with open(version_path, 'r') as f:
FileNotFoundError: [Errno 2] No such file or directory: '/mnt/.ix-apps/truenas_catalog/trains/stable/nextcloud/app_versions.json'
File "/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py", line 323, in process_method_call
result = await method.call(app, params)
File "/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py", line 40, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 883, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 703, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 596, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 96, in wrapped
result = func(*args)
File "/usr/lib/python3/dist-packages/middlewared/plugins/catalog/app_version.py", line 43, in get_app_details
app_details = get_app_details(app_location, train_data[options['train']][app_name], questions_context)
File "/usr/lib/python3/dist-packages/middlewared/plugins/catalog/apps_util.py", line 96, in get_app_details
app_data['versions'] = retrieve_cached_versions_data(os.path.join(app_location, CACHED_VERSION_FILE_NAME), app_name)
File "/usr/lib/python3/dist-packages/middlewared/plugins/catalog/apps_util.py", line 119, in retrieve_cached_versions_data
raise CallError(f'Unable to locate {app_name!r} versions', errno=errno.ENOENT)
middlewared.service_exception.CallError: [ENOENT] Unable to locate 'nextcloud' versions
Thanks!
