Error in Nextcloud with TrueNAS Scale?
Would someone know how to fix this error in nextcloud on truenas scale An exception occured while running the setup check: InvalidArgumentException: URL is missing scheme or host in /var/www/html/apps/settings/lib/SetupChecks/CheckServerResponseTrait.php:97 Stack trace: #0 /var/www/html/apps/settings/lib/SetupChecks/CheckServerResponseTrait.php(61): OCA\Settings\SetupChecks\WellKnownUrls->normalizeUrl(‘nextcloud.pohlc…’, true) #1 /var/www/html/apps/settings/lib/SetupChecks/CheckServerResponseTrait.php(130): OCA\Settings\SetupChecks\WellKnownUrls->getTestUrls(‘/.well-known/we…’, true) #2 /var/www/html/apps/settings/lib/SetupChecks/WellKnownUrls.php(56): OCA\Settings\SetupChecks\WellKnownUrls->runRequest(‘get’, ‘/.well-known/we…’, Array, true) #3 /var/www/html/lib/private/SetupCheck/SetupCheckManager.php(34): OCA\Settings\SetupChecks\WellKnownUrls->run() #4 /var/www/html/apps/settings/lib/Controller/CheckSetupController.php(147): OC\SetupCheck\SetupCheckManager->runAll() #5 /var/www/html/lib/private/AppFramework/Http/Dispatcher.php(208): OCA\Settings\Controller\CheckSetupController->check() #6 /var/www/html/lib/private/AppFramework/Http/Dispatcher.php(114): OC\AppFramework\Http\Dispatcher->executeController(Object(OCA\Settings\Controller\CheckSetupController), ‘check’) #7 /var/www/html/lib/private/AppFramework/App.php(161): OC\AppFramework\Http\Dispatcher->dispatch(Object(OCA\Settings\Controller\CheckSetupController), ‘check’) #8 /var/www/html/lib/private/Route/Router.php(302): OC\AppFramework\App::main(‘OCA\Settings\Co…’, ‘check’, Object(OC\AppFramework\DependencyInjection\DIContainer), Array) #9 /var/www/html/lib/base.php(1003): OC\Route\Router->match(‘/settings/ajax/…’) #10 /var/www/html/index.php(24): OC::handleRequest() #11 {main}
I am new with truenas scale Electric eel, so I don’t know how to enter the shell for nextcloud. Thank you for any help
