My computer cannot connect to the Internet properly, so I set up a network proxy. When I create a new container → select an image → browse the directory, the following error appears.
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1098, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs, sock=sock)
File “/usr/lib/python3.11/asyncio/base_events.py”, line 1113, in create_connection
transport, protocol = await self._create_connection_transport(
File “/usr/lib/python3.11/asyncio/base_events.py”, line 1146, in _create_connection_transport
await waiter
File “/usr/lib/python3.11/asyncio/selector_events.py”, line 974, in _read_ready__get_buffer
nbytes = self._sock.recv_into(buf)
ConnectionResetError: [Errno 104] Connection reset by peer
The above exception was the direct cause of the following exception:
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py”, line 323, in process_method_call
result = await method.call(app, params)
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py”, line 40, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 883, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 692, in _call
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 88, in wrapped
result = await func(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/virt/instance.py”, line 314, in image_choices
async with session.get(url) as resp:
File “/usr/lib/python3/dist-packages/aiohttp/client.py”, line 1359, in aenter
self._resp: _RetType = await self._coro
File “/usr/lib/python3/dist-packages/aiohttp/client.py”, line 663, in _request
conn = await self._connector.connect(
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 563, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1032, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1366, in _create_direct_connection
raise last_exc
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1335, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1106, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host images.linuxcontainers.org:443 ssl:default [Connection reset by peer]
After investigation, I found that the aiohttp library in Python causes this problem when using a proxy to request an https page. Is there a solution?
