Failed to connect to libvirt
Hi community, have a problem with the KVM virtualization on TrueNAS Dragonfish. The UI gives me this error when I open the VIrtualization page:
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 198, in call_method
    result = await self.middleware.call_with_audit(message['method'], serviceobj, methodobj, params, self)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1466, in call_with_audit
    result = await self._call(method, serviceobj, methodobj, params, app=app,
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1417, in _call
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 47, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 187, in nf
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 166, in query
    result = await self.middleware.call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1564, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 149, in query
    result = await self._queryset_serialize(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 197, in _queryset_serialize
    extend_context_value = await self.middleware.call(extend_context, rows, extra_options)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1428, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1321, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 103, in extend_context
    self._check_setup_connection()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 71, in _check_setup_connection
    self._check_connection_alive()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 66, in _check_connection_alive
    raise CallError('Failed to connect to libvirt')
middlewared.service_exception.CallError: [EFAULT] Failed to connect to libvirt
I think this started to show after I ran
systemctl unmask libvirtd.socket
systemctl restart libvirtd.service
in order to get the virsh CLI to work. I guess I shouldn’t run everything I find on the internet :sweat_smile:
Does anyone know how to fix this?
Did you solve this?
@Mathias_Ewald Hi, did you ever solve this?
