First Issue with First Build - Lable is missing or invalid
Hi all,
After many years of debating off the shelf vs DIY NAS’s, I finally decided to take the plunge and went the DIY route. Whilst my PC building skills are good and my DOS knowledge is (probably was now…) decent, my Linux knowledge is lacking, hence the whole DIY route also being a learning curve!
The hardware is a HP Microserver Gen8 with upgraded CPU to i5-3470T, 16Gb ECC Ram, LSI 9212 HBA Card with 4x 3Gb SAS drives in Raid1z and 2x240Gb SDD in Mirror for meta. Boot is off a 32Gb endurance SD card, running Dragonfish-24.04.2.2.
Ideally, I wanted to play around with various containers and dockage related items, but even before I could start that joruney I was greeted with
“Alerts”
Pool swimming state is DEGRADED: One or more devices could not be used because the lable is missing or invalid. Sufficent replicas exist for the pool to continue fuctioning in a degraded state.
The following devices are not healthy:
Disk MB3000FBNWV Z292Y5QQ00009244E57G is UNAVAIL
Steps performed so far.
Power downed and check all cables, ports and drives are secure
Ton of googling to figure out what this means
What I thought I could have done is given the drive seems to show in the Storage Dashboard as 1 Unassigned Disks, I could press the Add To Pool button and go through the motions, but this doesnt allow me to add 1 drive to the existing pool as it says its not enough drives to do so (can send s/s if needed)
Therefore, I think what I need to do is to Export the pool (unticking destroy and delete config) and Import the pool again, but I dont know if I need to “save” any config anywhere prior and where to do “import” from and what this means for the data in the pool.
Doing what seems advance, but basic to you guys is some tests and i see that sdc is the one thats dropped out, but i dont get how or why or now what to do to “put it back in”.
lsblk
admin@truenas[~]$ lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
sda           8:0    0   2.7T  0 disk
├─sda1        8:1    0     2G  0 part
│ └─md127     9:127  0     2G  0 raid1
│   └─md127 253:1    0     2G  0 crypt
└─sda2        8:2    0   2.7T  0 part
sdb           8:16   0   2.7T  0 disk
├─sdb1        8:17   0     2G  0 part
│ └─md126     9:126  0     2G  0 raid1
│   └─md126 253:0    0     2G  0 crypt
└─sdb2        8:18   0   2.7T  0 part
sdc           8:32   0     0B  0 disk
sdd           8:48   0   2.7T  0 disk
├─sdd1        8:49   0     2G  0 part
└─sdd2        8:50   0   2.7T  0 part
sde           8:64   0  29.7G  0 disk
├─sde1        8:65   0     1M  0 part
├─sde2        8:66   0   512M  0 part
└─sde3        8:67   0  13.9G  0 part
sdf           8:80   0 223.6G  0 disk
└─sdf1        8:81   0 223.6G  0 part
sdg           8:96   0 223.6G  0 disk
└─sdg1        8:97   0 223.6G  0 part
admin@truenas[~]$
zpool status -v
admin@truenas[~]$ sudo zpool status -v
[sudo] password for admin:
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:05:21 with 0 errors on Sat Oct 12 03:50:23 2024
        NAME                                                  STATE     READ WRITE CKSUM
        boot-pool                                             ONLINE       0     0     0
          usb-HP_iLO_Internal_SD-CARD_000002660A01-0:0-part3  ONLINE       0     0     0
errors: No known data errors
  pool: swimming
 state: DEGRADED
status: One or more devices could not be used because the label is missing or
        invalid.  Sufficient replicas exist for the pool to continue
        functioning in a degraded state.
action: Replace the device using 'zpool replace'.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-4J
  scan: scrub repaired 0B in 00:07:24 with 0 errors on Wed Oct 16 13:39:11 2024
        swimming                                  DEGRADED     0     0     0
          raidz1-0                                DEGRADED     0     0     0
            3252fd4c-4b6a-4a42-8f0d-6b0192f76d9d  ONLINE       0     0     0
            65dd5986-43f2-4ec5-ad4e-b9f070d43749  ONLINE       0     0     0
            3038990180868011873                   UNAVAIL      0     0     0  was /dev/disk/by-partuuid/e00549c2-3561-435a-99aa-bea96ee0986a
            2954b660-800c-4f87-9fa2-84ce4ea439c9  ONLINE       0     0     0
        special
          mirror-1                                ONLINE       0     0     0
            5fc5e1d5-ee2c-4761-8229-65c7acc18856  ONLINE       0     0     0
            95fb2eeb-b758-4837-bfa2-9a1e8882df13  ONLINE       0     0     0
zfs list
admin@truenas[~]$ sudo zfs list
NAME                                                        USED  AVAIL  REFER  MOUNTPOINT
boot-pool                                                  4.81G  8.27G    96K  none
boot-pool/ROOT                                             4.79G  8.27G    96K  none
boot-pool/ROOT/24.04.0                                     2.39G  8.27G   164M  legacy
boot-pool/ROOT/24.04.0/audit                                140K  8.27G   140K  /audit
boot-pool/ROOT/24.04.0/conf                                 140K  8.27G   140K  /conf
boot-pool/ROOT/24.04.0/data                                  88K  8.27G   272K  /data
boot-pool/ROOT/24.04.0/etc                                 6.53M  8.27G  5.63M  /etc
boot-pool/ROOT/24.04.0/home                                   0B  8.27G   116K  /home
boot-pool/ROOT/24.04.0/mnt                                   96K  8.27G    96K  /mnt
boot-pool/ROOT/24.04.0/opt                                 74.1M  8.27G  74.1M  /opt
boot-pool/ROOT/24.04.0/root                                   8K  8.27G   156K  /root
boot-pool/ROOT/24.04.0/usr                                 2.12G  8.27G  2.12G  /usr
boot-pool/ROOT/24.04.0/var                                 31.8M  8.27G  30.3M  /var
boot-pool/ROOT/24.04.0/var/ca-certificates                   96K  8.27G    96K  /var/local/ca-certificates
boot-pool/ROOT/24.04.0/var/log                              448K  8.27G  3.32M  /var/log
boot-pool/ROOT/24.04.2.2                                   2.41G  8.27G   164M  legacy
boot-pool/ROOT/24.04.2.2/audit                              372K  8.27G   372K  /audit
boot-pool/ROOT/24.04.2.2/conf                               132K  8.27G   132K  /conf
boot-pool/ROOT/24.04.2.2/data                               516K  8.27G   280K  /data
boot-pool/ROOT/24.04.2.2/etc                               6.59M  8.27G  5.63M  /etc
boot-pool/ROOT/24.04.2.2/home                               216K  8.27G   128K  /home
boot-pool/ROOT/24.04.2.2/mnt                                 96K  8.27G    96K  /mnt
boot-pool/ROOT/24.04.2.2/opt                               74.1M  8.27G  74.1M  /opt
boot-pool/ROOT/24.04.2.2/root                               272K  8.27G   172K  /root
boot-pool/ROOT/24.04.2.2/usr                               2.12G  8.27G  2.12G  /usr
boot-pool/ROOT/24.04.2.2/var                               46.2M  8.27G  32.1M  /var
boot-pool/ROOT/24.04.2.2/var/ca-certificates                 96K  8.27G    96K  /var/local/ca-certificates
boot-pool/ROOT/24.04.2.2/var/log                           13.1M  8.27G  12.7M  /var/log
boot-pool/grub                                             8.16M  8.27G  8.16M  legacy
swimming                                                    351G  7.46T    96K  /mnt/swimming
swimming/.system                                           1.34G  7.46T  1.23G  legacy
swimming/.system/configs-8f179c8648fc4419af075a5cf26c19f8   827K  7.46T   827K  legacy
swimming/.system/cores                                       96K  1024M    96K  legacy
swimming/.system/netdata-8f179c8648fc4419af075a5cf26c19f8   112M  7.46T   112M  legacy
swimming/.system/samba4                                     243K  7.46T   243K  legacy
swimming/test                                               349G  7.46T   349G  /mnt/swimming/test
admin@truenas[~]$
sas2flash -list
admin@truenas[~]$ sudo sas2flash -list
LSI Corporation SAS2 Flash Utility
Version 20.00.00.00 (2014.09.18)
Copyright (c) 2008-2014 LSI Corporation. All rights reserved
        Adapter Selected is a LSI SAS: SAS2308_2(D1)
        Controller Number              : 0
        Controller                     : SAS2308_2(D1)
        PCI Address                    : 00:07:00:00
        SAS Address                    : 500605b-0-0cf8-aba0
        NVDATA Version (Default)       : 11.00.00.02
        NVDATA Version (Persistent)    : 11.00.00.02
        Firmware Product ID            : 0x2714 (IR)
        Firmware Version               : 18.00.00.00
        NVDATA Vendor                  : LSI
        NVDATA Product ID              : SAS9217-4i4e
        BIOS Version                   : N/A
        UEFI BSD Version               : N/A
        FCODE Version                  : N/A
        Board Name                     : SAS9217-4i4e
        Board Assembly                 : 03-25597-01B
        Board Tracer Number            : SP72519732
        Finished Processing Commands Successfully.
        Exiting SAS2Flash.
admin@truenas[~]$
Hope theres enough information to help me out and looking to learn as well so thank you in advance!
The HBA is on an old P18 firmware. Upgrade it to the latest P20
