Forgejo not starting after 1.2.6
App will not start after update. I have such a vanilla set up, I think it must be a system issue. Anybody else?
I tried basic troubleshooting. I know docker but am new to Truenas. I restarted, unset and reset the pool, and rolled the dataset back to yesterday. I cannot see a way to roll back the version of Forgejo; it looks like the app must be running to do that.
If nobody else is having the problem, feel free to ignore! I will wait a few days and then wipe and reinstall Forgejo. Thanks!
did you check the lifecycle log?
sudo cat /var/log/app_lifecycle.log
should give you an idea why it fails to start
Thanks Lars! I did check that file and other logs. It looks like a download fails with “5.951MB/17.74MB\nunexpected EOF\n”. I checked that right away and thought it could be the rate limit. I doubt it, because I do not have many docker pulls. But I added a login to the docker registry and tried again after a restart. Same results.
Back up!!!
I knew I should have just waited. Sorry all! The Forgejo is backup. Ironically, the logs show an error.
[2026/03/12 18:37:16] (ERROR) app_lifecycle.compose_action():58 - Failed ‘up’ action for ‘forgejo’ app: Timed out waiting for response
