Thanks for the suggestion but all times are in sync and correlate with my PC’s clock.
I have found that it seems that TrueNAS cannot “get out” ie. it cannot send a test email and now I find that I cannot connect to MS One Drive either:
Error Name: EINVAL
Error Code: 22
Reason: HTTPSConnectionPool(host=‘graph.microsoft.com’, port=443): Max retries exceeded with url: /v1.0/me/drives (Caused by NewConnectionError(‘<urllib3.connection.HTTPSConnection object at 0x7f8068ced850>: Failed to establish a new connection: [Errno 101] Network is unreachable’))
Error Class: ConnectionError
Trace: Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 174, in _new_conn
conn = connection.create_connection(
File “/usr/lib/python3/dist-packages/urllib3/util/connection.py”, line 96, in create_connection
raise err
File “/usr/lib/python3/dist-packages/urllib3/util/connection.py”, line 86, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network is unreachable
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 705, in urlopen
httplib_response = self._make_request(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 388, in _make_request
self._validate_conn(conn)
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 1050, in _validate_conn
conn.connect()
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 358, in connect
self.sock = conn = self._new_conn()
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7f8068ced850>: Failed to establish a new connection: [Errno 101] Network is unreachable
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 489, in send
resp = conn.urlopen(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 789, in urlopen
retries = retries.increment(
File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 594, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘graph.microsoft.com’, port=443): Max retries exceeded with url: /v1.0/me/drives (Caused by NewConnectionError(‘<urllib3.connection.HTTPSConnection object at 0x7f8068ced850>: Failed to establish a new connection: [Errno 101] Network is unreachable’))
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py”, line 361, in process_method_call
result = await method.call(app, id_, params)
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py”, line 57, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 956, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 784, in _call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 667, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 116, in wrapped
result = func(*args)
File “/usr/lib/python3/dist-packages/middlewared/rclone/remote/onedrive.py”, line 51, in list_drives
r = requests.get(
File “/usr/lib/python3/dist-packages/requests/api.py”, line 73, in get
return request(“get”, url, params=params, **kwargs)
File “/usr/lib/python3/dist-packages/requests/api.py”, line 59, in request
return session.request(method=method, url=url, **kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 587, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 701, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 565, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘graph.microsoft.com’, port=443): Max retries exceeded with url: /v1.0/me/drives (Caused by NewConnectionError(‘<urllib3.connection.HTTPSConnection object at 0x7f8068ced850>: Failed to establish a new connection: [Errno 101] Network is unreachable’))
I am wondering if there is something amiss between TrueNAS and my Router, but I have logged into the router and cannot see anything that looks different from the settings in TNAS. I am stumped.
