Here is ada1
root@truenas[~]# smartctl -a /dev/ada1
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p12 amd64] (local build)
Device Model: WDC WD60EFPX-68C5ZN0
Serial Number: WD-WX12A82CDLSA
LU WWN Device Id: 5 0014ee 26ab99225
Firmware Version: 81.00A81
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Apr 17 16:23:10 2024 PDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (61020) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 633) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3039) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 232 225 021 Pre-fail Always - 3375
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 20
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 2595
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 20
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 43
194 Temperature_Celsius 0x0022 127 123 000 Old_age Always - 23
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 1294 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada2
root@truenas[~]# smartctl -a /dev/ada2
Model Family: Western Digital Red (SMR)
Device Model: WDC WD60EFAX-68JH4N1
Serial Number: WD-WX82DA1ECXAT
LU WWN Device Id: 5 0014ee 26a15108f
Firmware Version: 83.00A83
TRIM Command: Available, deterministic, zeroed
Local Time is: Wed Apr 17 16:24:07 2024 PDT
was never started.
been run.
data collection: (13184) seconds.
command.
power-saving mode.
recommended polling time: ( 771) minutes.
recommended polling time: ( 3) minutes.
3 Spin_Up_Time 0x0027 229 218 021 Pre-fail Always - 3550
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 117
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 077 077 000 Old_age Always - 16949
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 116
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 93
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 46
194 Temperature_Celsius 0x0022 124 115 000 Old_age Always - 26
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
No Errors Logged
# 1 Short offline Completed without error 00% 15647 -
# 2 Short offline Completed without error 00% 22 -
# 3 Short offline Completed without error 00% 22 -
# 4 Extended offline Completed without error 00% 19 -
# 5 Short offline Completed without error 00% 15 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada3
root@truenas[~]# smartctl -a /dev/ada3
Serial Number: WD-WX92DA163Y24
LU WWN Device Id: 5 0014ee 2bf6bd38e
Local Time is: Wed Apr 17 16:24:37 2024 PDT
was never started.
been run.
command.
power-saving mode.
recommended polling time: ( 780) minutes.
3 Spin_Up_Time 0x0027 236 222 021 Pre-fail Always - 3166
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 108
9 Power_On_Hours 0x0032 077 077 000 Old_age Always - 16951
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 107
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 84
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 50
194 Temperature_Celsius 0x0022 126 116 000 Old_age Always - 24
No Errors Logged
# 1 Short offline Completed without error 00% 16921 -
# 2 Short offline Completed without error 00% 15650 -
# 3 Short offline Completed without error 00% 15649 -
# 4 Conveyance offline Completed without error 00% 22 -
# 5 Conveyance offline Completed without error 00% 22 -
# 6 Short offline Completed without error 00% 22 -
# 7 Short offline Completed without error 00% 22 -
# 8 Extended offline Completed without error 00% 19 -
# 9 Short offline Completed without error 00% 15 -
#10 Short offline Completed without error 00% 3 -
#11 Short offline Interrupted (host reset) 20% 2 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada4
root@truenas[~]# smartctl -a /dev/ada4
Serial Number: WD-WXB2DA16UYR1
LU WWN Device Id: 5 0014ee 2bf6d59b4
Local Time is: Wed Apr 17 16:25:00 2024 PDT
was never started.
been run.
data collection: (37844) seconds.
command.
power-saving mode.
recommended polling time: ( 738) minutes.
3 Spin_Up_Time 0x0027 232 220 021 Pre-fail Always - 3400
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 116
9 Power_On_Hours 0x0032 077 077 000 Old_age Always - 16950
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 115
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 92
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 41
194 Temperature_Celsius 0x0022 123 114 000 Old_age Always - 27
No Errors Logged
# 1 Short offline Completed without error 00% 22 -
# 3 Short offline Completed without error 00% 19 -
# 6 Short offline Completed without error 00% 15 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada5
root@truenas[~]# smartctl -a /dev/ada5
Serial Number: WD-WXA2DA1C9CCA
LU WWN Device Id: 5 0014ee 214c2277e
Local Time is: Wed Apr 17 16:25:25 2024 PDT
was never started.
been run.
data collection: (11444) seconds.
command.
power-saving mode.
recommended polling time: ( 776) minutes.
3 Spin_Up_Time 0x0027 229 219 021 Pre-fail Always - 3533
9 Power_On_Hours 0x0032 077 077 000 Old_age Always - 16939
No Errors Logged
# 3 Extended offline Completed without error 00% 19 -
# 4 Short offline Completed without error 00% 15 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
