Hard copy of data with replication
Just want to make sure im not going to completely screw myself. I want to move all of my data from pool A to pool B so i can destroy and reconfigure pool A. If i do a recursive full file system replication from A to B and then rollback the snapshots on B, that will do the equivalent of an actual copy/rsync and physically put the actual files onto pool B so they would have no connection/dependency to pool A, correct?
I would just copy them and be done with it, but i dont feel like redoing my dataset tree and permissions/ownership all again.
Yes.
Muchos :+1:
The forums are so much more boring, now that they got rid of the minimum character requirement. :frowning_face:
Why rollback?
Rolling back is destroying data.
If you want the files from A on B, replicate from A to B. Don’t rollback or you will undo the replication!
How would a rollback destroy data if I do it on the latest snapshot that gets replicated right after it is done? I actually did a replication before, then deleting the snapshots on pool B deleted everything, so doesn’t that mean only a replication doesn’t actually deposit “real” data?
