The problem I’m having:
Hi, I’m trying to use Caddy as a reverse proxy for a Home Assistant VM hosted on Truenas.
- Caddy is installed as a Truenas application (docker)
- Caddy is latest version:
v2.10.0 - Caddy is already acting as a reverse proxy to other applications (but not VMs) on the same Truenas machine.
- The Home Assistant VM is accessible locally at http://192.168.1.35:8123.
- When I attempt to connect via caddy on https://home.sebt.one I get an error 502 (Bad Gateway)
Error message on Caddy :
2025-08-15 16:17:12.466667+00:00{"level":"error","ts":1755274632.466511,"logger":"http.log.error","msg":"dial tcp 192.168.1.35:8123: connect: no route to host","request":{"remote_ip":"192.168.1.254","remote_port":"48290","client_ip":"192.168.1.254","proto":"HTTP/2.0","method":"GET","host":"home.sebt.one","uri":"/","headers":{"Sec-Fetch-Dest":["document"],"Sec-Fetch-Site":["none"],"Priority":["u=0, i"],"Sec-Fetch-User":["?1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:141.0) Gecko/20100101 Firefox/141.0"],"Sec-Fetch-Mode":["navigate"],"Accept-Language":["en-US,en;q=0.5"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Gpc":["1"],"Upgrade-Insecure-Requests":["1"],"Te":["trailers"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"home.sebt.one"}},"duration":1.254436976,"status":502,"err_id":"rbrdc0ca8","err_trace":"reverseproxy.statusError (reverseproxy.go:1390)"}
Truenas version:
25.04.2.1
Caddy details
Compose
services:
caddy:
image: caddy:latest
restart: unless-stopped
environment:
- PUID=568
- PGID=568
- TZ=Europe/Paris
cap_add:
- NET_ADMIN
ports:
- "80:80"
- "443:443"
- "443:443/udp"
volumes:
- /mnt/SSD-Mirror/services/caddy/data:/data
- /mnt/SSD-Mirror/services/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/truenas_admin/websites/:/websites
Relevant Caddy config:
home.sebt.one {
reverse_proxy 192.168.1.35:8123
(obviously there are other lines for the other services but this is the only part that’s relevant)
Additional Info
I have tried adding a bridge (as I have seen this being mentioned on other similar threads) but this operation fails when I attempt it.
If you need any additional information from me please ask.
Thank you for any help. ![]()
