Hello, I’m having issues allocating GPU to apps, I currently have 2 GPU’s on system Quadro M4000 & K2200 both of them are showing in nvidia-smi also in lspci but non of them are showing on apps to GPU settings sections only shows Allocate 0 nvidia GPU however when I isolate K2200 for few minutes it it shows on settings to Allocate from 1 to 10 nvidia GPU, when i allocate and re-deploy the app it says: truenas scale 0/1 nodes are available: 1 Insufficient nvidia.com/gpu. preemption: 0/1 nodes are available: 1 No preemption victims found for incoming pod… and app doens’t deploy and it goes back to Allocate 0 nvidia.com/gpu GPU.
I’m having the same issue with two P2000s. They are visible with lspci, but I can’t allocate them via the plex config settings. This in the plex container app, not in a VM. This guy in a 2 year old video says that only Intel iGPUs are capable of HW transcoding with TrueNAS Scale. Not sure if this is still the case or not.
