What I do. I make custom icons for my folders. Then i put the icon in a subfolder. I then go into properties - customize and change the icon of the folder. Then i modify the path in desktop.ini file. Then i cut the folder and move it off my C drive to its final destination on truenas dataset.
What happened. After a system reboot. I can no longer copy or cut a folder and move it to truenas without the file permissions getting turned off. Hidden files are no longer hidden, system files will no longer have the /s attribute.
What i have tried. At first I though this was a windows problem, I tried different versions of windows, No luck. Then I tried to use a tool to change attribute properties and as soon as I change them the file gets changed back.
