This is more of a Plugin jail question than a NextCloud question, but for background… Many years ago I made the mistake of installing NextCloud via plugin. Early on I found it challenging to upgrade NextCloud, and doing a jail upgrade via the GUI would break it, so I kind of gave up. I’ve been trying to migrate to a clean jail/install on and off for a few years now.
I think my biggest hurdle is that I can’t migrate straight from NextCloud 17 to 30; when I drop and reload the database it breaks the new install. So that’s where my focus is now.
Truenas CORE is up to date 13.3. The jail is running 11.2-RELEASE-p15. When I try a CLI jail upgrade to 13.3, Truenas checks the plugins train and finds that it doesn’t exist anymore.
root@truenas:~ # iocage upgrade nextcloud
Branch 13.3-RELEASE does not exist at https://github.com/freenas/iocage-plugin-nextcloud.git!
Using "master" branch for plugin, this may not work with your RELEASE
New plugin RELEASE missing, fetching now...
13.2-RELEASE was not found!
I know editing files on Truenas isn’t recommended, but I can change it back when I’m done: is there ANY way to force Truenas to use a different repository for upgrading a jail created via plugin? If so, what file do I edit, and what’s the address?
Alternatively within the jail, I can try pkg update and at least try to get dependencies for newer versions of NextCloud. The problem there is that it looks in “pkg: http://pkg.FreeBSD.org/FreeBSD:11:amd64/latest/meta.txz” and FreeBSD:11:amd64 doesn’t exit anymore. When I look here (http://pkg.freebsd.org/) there’s nothing before FreeBSD:13. Is there an alternate pkg repository for FreeBSD:11 I can tell it to use instead?
