I’ve been constantly having difficulties with apps stuck at deploy and I noticed SMB access and permission errors are usually the culprit. Is there a guide standard ACL setup for app host paths? If not would it be a good idea to note the required access requirement in the apps setting page?
Specifically I’ve been trying to get immich to work for a while now I have all 7 host paths on the local system it is stuck at deploy without useful debugging information. I’ve been using photo program and had constant issues with apps bricking as well. Note postgres is on ssd. I have set the owner for all of the host path to apps, and no smb access, but it was unsuccessful. Any ideas?
Much thanks!
Lastly, for the more experienced out there, would you recommend running immich on a separate computer in Docker and would that significantly reduce the chance of apps bricking itself?
