Hi all,
Bug report didn’t go as hoped so I need to redo my personal apps catalog.
How would you guys go about this task? I’m thinking all custom apps should be easy as their docker-compose.yaml are available in the rendered(?) folder of that app’s app_config directory system. Easy to read and grab important mounts, ports, env vars, etc from.
Are there simple formatting of docker-compose’s available - with my filled in ix-apps settings? I’m going to have to format and reinstall my TrueNAS I think and perhaps start with zero configuration, unless I can remove the apps portion from the config export.
When I am finally as ready as I can be, I will start by rebooting my machine and unsetting the pool and backing up the app_config/app_mounts dirs. Some apps I luckily have started a config/data host path(s) for.
