admin@truenas[~]$ cat /etc/version
23.10.2%
Do you by any chance have an additional boot device (preserving your old install separately) that you can install 25.04.0 on and attempt to import there.
I should be able to manage that. I’ll give it a go.
Thank you, by the way. I appreciate your help.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/pool_actions.py", line 233, in import_pool
zfs.import_pool(found, pool_name, properties, missing_log=missing_log, any_host=any_host)
File "libzfs.pyx", line 1374, in libzfs.ZFS.import_pool
File "libzfs.pyx", line 1402, in libzfs.ZFS.__import_pool
libzfs.ZFSException: cannot import 'Diskof1337' as 'Diskof1337': I/O error
File "/usr/lib/python3.11/concurrent/futures/process.py", line 261, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 116, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 47, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 41, in _call
return methodobj(*params)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 178, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/pool_actions.py", line 213, in import_pool
with libzfs.ZFS() as zfs:
File "libzfs.pyx", line 534, in libzfs.ZFS.__exit__
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/pool_actions.py", line 237, in import_pool
raise CallError(f'Failed to import {pool_name!r} pool: {e}', e.code)
middlewared.service_exception.CallError: [EZFS_IO] Failed to import 'Diskof1337' pool: cannot import 'Diskof1337' as 'Diskof1337': I/O error
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 560, in __run_body
rv = await self.method(*args)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 174, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 48, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/import_pool.py", line 118, in import_pool
await self.middleware.call('zfs.pool.import_pool', guid, opts, any_host, use_cachefile, new_name)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 977, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 700, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 706, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 612, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 596, in run_in_executor
That is the output I get from the GUI when trying to import on a fresh install of 25.04.0
If you do the same
sudo zpool import -R /mnt -fFX Diskof1337
on 25.04, what’s the result?
If it fails to import, please copy the contents of the file /proc/spl/kstat/zfs/dbgmsg (cat it to the screen or a file) and paste it here inside a code block (triple-backticks)
code goes here
truenas_admin@truenas[~]$ sudo zpool import -R /mnt -fFX Diskof1337
[sudo] password for truenas_admin:
cannot import 'Diskof1337': one or more devices is currently unavailable
1746028198 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028198 ffff9d6290701980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028198 ffff9d6290701980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028198 ffff9d6290701980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028198 ffff9d6290701980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028198 ffff9d6290701980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028198 ffff9d6290701980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028199 ffff9d629ba38000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1014941079/1000000000
1746028199 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47655
1746028199 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47655)
1746028199 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028199 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47655
1746028199 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028199 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028199 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47654
1746028199 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028199 ffff9d6380d88000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028199 ffff9d6380d88000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028199 ffff9d6380d88000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028199 ffff9d6380d88000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028199 ffff9d6380d88000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028199 ffff9d6380d88000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028200 ffff9d6374d4cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1007746804/1000000000
1746028200 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47654
1746028200 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47654)
1746028200 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028200 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47654
1746028200 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028200 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028200 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47653
1746028200 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028200 ffff9d6382794c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028200 ffff9d6382794c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028200 ffff9d6382794c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028200 ffff9d6382794c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028200 ffff9d6382794c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028200 ffff9d6382794c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028201 ffff9d6375cae600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1004501873/1000000000
1746028201 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47653
1746028201 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47653)
1746028201 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028201 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47653
1746028201 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028201 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028201 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47652
1746028201 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028201 ffff9d6377ce6600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028201 ffff9d6377ce6600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028201 ffff9d6377ce6600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028201 ffff9d6377ce6600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028201 ffff9d6377ce6600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028201 ffff9d6377ce6600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028202 ffff9d6382909980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1014631480/1000000000
1746028203 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47652
1746028203 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47652)
1746028203 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028203 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47652
1746028203 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028203 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028203 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47651
1746028203 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028203 ffff9d62bc51cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028203 ffff9d62bc51cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028203 ffff9d62bc51cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028203 ffff9d62bc51cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028203 ffff9d62bc51cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028203 ffff9d62bc51cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028204 ffff9d6375ca9980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1005643443/1000000000
1746028204 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47651
1746028204 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47651)
1746028204 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028204 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47651
1746028204 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028204 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028204 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47650
1746028204 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028204 ffff9d629f191980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028204 ffff9d629f191980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028204 ffff9d629f191980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028204 ffff9d629f191980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028204 ffff9d629f191980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028204 ffff9d629f191980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028205 ffff9d629b660000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1004916925/1000000000
1746028205 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47650
1746028205 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47650)
1746028205 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028205 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47650
1746028205 ffff9d6290b79980 vdev_raidz.c:2722:raidz_parity_verify(): found error on col=1 devidx=4 off 27bc46a7000
1746028205 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028205 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028205 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47649
1746028205 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028205 ffff9d6381e26600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028205 ffff9d6381e26600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028205 ffff9d6381e26600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028205 ffff9d6381e26600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028205 ffff9d6381e26600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028205 ffff9d6381e26600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028206 ffff9d629b661980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1007973941/1000000000
1746028206 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47649
1746028206 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47649)
1746028206 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028206 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47649
1746028206 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028206 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028206 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47648
1746028206 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028206 ffff9d62bd44cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028206 ffff9d62bd44cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028206 ffff9d62bd44cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028206 ffff9d62bd44cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028206 ffff9d62bd44cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028206 ffff9d62bd44cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028207 ffff9d6381c0b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1011500046/1000000000
1746028207 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47648
1746028207 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47648)
1746028207 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028207 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47648
1746028207 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028207 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028207 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47647
1746028207 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028207 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028207 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028207 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028207 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028207 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028207 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028208 ffff9d629e5ae600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1005249970/1000000000
1746028208 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47647
1746028208 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47647)
1746028208 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028208 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47647
1746028208 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028208 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028208 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47646
1746028208 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028208 ffff9d63828f1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028208 ffff9d63828f1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028208 ffff9d63828f1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028208 ffff9d63828f1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028208 ffff9d63828f1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028208 ffff9d63828f1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028209 ffff9d62a7c1cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1011025129/1000000000
1746028209 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47645
1746028209 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47645)
1746028209 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028209 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47645
1746028209 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028209 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028209 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47644
1746028209 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028209 ffff9d63a9d4e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028209 ffff9d63a9d4e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028209 ffff9d63a9d4e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028209 ffff9d63a9d4e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028209 ffff9d63a9d4e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028209 ffff9d63a9d4e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028210 ffff9d629b661980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1010323645/1000000000
1746028210 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47644
1746028211 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47644)
1746028211 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028211 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47644
1746028211 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028211 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028211 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47643
1746028211 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028211 ffff9d6380460000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028211 ffff9d6380460000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028211 ffff9d6380460000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028211 ffff9d6380460000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028211 ffff9d6380460000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028211 ffff9d6380460000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028212 ffff9d638299e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1014439385/1000000000
1746028212 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47643
1746028212 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47643)
1746028212 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028212 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47643
1746028212 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028212 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028212 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47642
1746028212 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028212 ffff9d629b6c4c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028212 ffff9d629b6c4c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028212 ffff9d629b6c4c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028212 ffff9d629b6c4c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028212 ffff9d629b6c4c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028212 ffff9d629b6c4c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028213 ffff9d62a7c1b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1010748809/1000000000
1746028213 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47642
1746028213 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47642)
1746028213 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028213 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47642
1746028213 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028213 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028213 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47641
1746028213 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028213 ffff9d629b6c1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028213 ffff9d629b6c1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028213 ffff9d629b6c1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028213 ffff9d629b6c1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028213 ffff9d629b6c1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028213 ffff9d629b6c1980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028214 ffff9d6382460000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1007168718/1000000000
1746028214 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47641
1746028214 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47641)
1746028214 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028214 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47641
1746028214 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028214 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028214 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47640
1746028214 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028214 ffff9d629b660000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028214 ffff9d629b660000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028214 ffff9d629b660000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028214 ffff9d629b660000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028214 ffff9d629b660000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028214 ffff9d629b660000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028215 ffff9d6381e28000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1006591585/1000000000
1746028215 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47640
1746028215 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47640)
1746028215 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028215 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47640
1746028215 ffff9d6382bccc80 vdev_raidz.c:2722:raidz_parity_verify(): found error on col=1 devidx=4 off 27bc466b000
1746028215 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028215 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028215 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47639
1746028215 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028215 ffff9d6290b34c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028215 ffff9d6290b34c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028215 ffff9d6290b34c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028215 ffff9d6290b34c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028215 ffff9d6290b34c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028215 ffff9d6290b34c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028216 ffff9d6382909980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1006049425/1000000000
1746028216 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47639
1746028216 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47639)
1746028216 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028216 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47639
1746028216 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028216 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028216 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47638
1746028216 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028216 ffff9d6382bc9980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028216 ffff9d6382bc9980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028216 ffff9d6382bc9980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028216 ffff9d6382bc9980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028216 ffff9d6382bc9980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028216 ffff9d6382bc9980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028217 ffff9d6382460000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1011756741/1000000000
1746028217 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47638
1746028217 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47638)
1746028217 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028217 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47638
1746028217 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028217 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028217 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47637
1746028217 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028217 ffff9d6290b79980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028217 ffff9d6290b79980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028217 ffff9d6290b79980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028217 ffff9d6290b79980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028217 ffff9d6290b79980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028217 ffff9d6290b79980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028218 ffff9d629b6c0000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1000932462/1000000000
1746028218 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47637
1746028218 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47637)
1746028218 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028218 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47637
1746028219 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028219 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028219 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47636
1746028219 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028219 ffff9d638299e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028219 ffff9d638299e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028219 ffff9d638299e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028219 ffff9d638299e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028219 ffff9d638299e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028219 ffff9d638299e600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028220 ffff9d6382bde600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1009410879/1000000000
1746028220 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47636
1746028220 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47636)
1746028220 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028220 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47636
1746028220 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028220 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028220 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47635
1746028220 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028220 ffff9d6382464c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028220 ffff9d6382464c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028220 ffff9d6382464c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028220 ffff9d6382464c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028220 ffff9d6382464c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028220 ffff9d6382464c80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028221 ffff9d6377319980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1006731848/1000000000
1746028221 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47635
1746028221 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47635)
1746028221 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028221 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47635
1746028221 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028221 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028221 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47634
1746028221 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028221 ffff9d6377319980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028221 ffff9d6377319980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028221 ffff9d6377319980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028221 ffff9d6377319980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028221 ffff9d6377319980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028221 ffff9d6377319980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028222 ffff9d629b6c0000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1010215428/1000000000
1746028222 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47634
1746028222 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47634)
1746028222 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028222 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47634
1746028222 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028222 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028222 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47633
1746028222 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028222 ffff9d6374d4cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028222 ffff9d6374d4cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028222 ffff9d6374d4cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028222 ffff9d6374d4cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028222 ffff9d6374d4cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028222 ffff9d6374d4cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028223 ffff9d6382999980 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1004622344/1000000000
1746028223 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47633
1746028223 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47633)
1746028223 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028223 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47633
1746028223 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028223 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028223 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47632
1746028223 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028223 ffff9d6382bccc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028223 ffff9d6382bccc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028223 ffff9d6382bccc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028223 ffff9d6382bccc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028223 ffff9d6382bccc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028223 ffff9d6382bccc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028224 ffff9d638293b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1006911152/1000000000
1746028224 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47632
1746028224 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47632)
1746028224 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028224 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47632
1746028224 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028224 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028224 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47631
1746028224 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028224 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028224 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028224 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028224 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028224 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028224 ffff9d629af0cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028225 ffff9d638290cc80 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1006691603/1000000000
1746028225 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': best uberblock found for spa Diskof1337. txg 47631
1746028225 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': label discarded as txg is too large (47662 > 47631)
1746028225 ffff9d6376c9b300 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': failed to read label config. Trying again without txg restrictions.
1746028225 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): using uberblock with txg=47631
1746028225 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: couldn't get 'config' value in MOS directory [error=5]
1746028225 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
1746028225 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): spa_load_retry: rewind, max txg: 47630
1746028225 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): LOADING
1746028225 ffff9d629ba38000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/ec63cdf7-16d7-4035-b1b6-63002dba1f42': probe done, cant_read=0 cant_write=1
1746028225 ffff9d629ba38000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/7cbeea3b-3497-40e0-9070-e74d7e139e3e': probe done, cant_read=0 cant_write=1
1746028225 ffff9d629ba38000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/3cab4e4a-2cd9-40e6-847f-a7960b18c910': probe done, cant_read=0 cant_write=1
1746028225 ffff9d629ba38000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/1a8ffb7f-40fe-48b5-a6c7-f5c426edb100': probe done, cant_read=0 cant_write=1
1746028225 ffff9d629ba38000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/2105541b-ec97-4100-b6fc-3bdae4fac837': probe done, cant_read=0 cant_write=1
1746028225 ffff9d629ba38000 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/c98caffe-a6c1-4e2e-a318-a58efa7aacd7': probe done, cant_read=0 cant_write=1
1746028226 ffff9d6382986600 vdev.c:183:vdev_dbgmsg(): disk vdev '/dev/disk/by-partuuid/e30b985b-ea3b-4b46-a941-1283c3a65e85': open error=2 timeout=1001420338/1000000000
1746028226 ffff9d6376c9b300 spa_misc.c:415:spa_load_failed(): spa_load(Diskof1337, config untrusted): FAILED: no valid uberblock found
1746028226 ffff9d6376c9b300 spa_misc.c:429:spa_load_note(): spa_load(Diskof1337, config untrusted): UNLOADING
It looks like this gets truncated in the shell, I’ll see if I can get the rest if this isn’t enough to go on.
Not only truncated by the shell… also triple the character limit of this forum lol
