Can I hear from those who have successfully made an Infinitude container work on their TrueNAS server please? Posting a .yaml file would be nice.
tried it with the yaml from their github, adjusted the storage path for a hostpath and got it working, added the code for a portal button and it deployed fine
Edit: before i deployed the app i created a new dataset with the apps preset.
services:
infinitude:
build:
context: .
dockerfile: Dockerfile
container_name: infinitude
environment:
- PUID=568
- PGID=568
- APP_SECRET=Pogotudinal
- PASS_REQS=300
- MODE=Production
hostname: infinitude
image: nebulous/infinitude:latest
network_mode: host
restart: always
volumes:
- /mnt/Plugins/test/state:/infinitude/state # adjust /mnt/Plugins/test/state to the hostpath you want to use
x-portals:
- host: 191.1.1.3 #adjust to your truenas ip
path: /
port: 3000
scheme: http
Thank you! I got mine working before seeing your reply; nevertheless, I see some interesting stuff in your YAML: What are PUID and PGID? I didn’t need that. Neither did I need the network_mode, nor the volumes.
It’s just to let the container run as user apps
Thanks. Anyway, here below is my YAML, and let me know if you see anything funny in it please.
services:
infinitude:
environment:
APP_SECRET: some_secret
MODE: Production
NVIDIA_VISIBLE_DEVICES: void
PASS_REQS: '300'
TZ: America/New_York
group_add:
- 568
platform: linux/amd64
ports:
- mode: ingress
protocol: tcp
published: 3000
target: 3000
privileged: False
pull_policy: missing
restart: always
stdin_open: False
tty: False
x-notes: >
# iX App
## Security
**Read the following security precautions to ensure that you wish to continue
using this application.**
### Container: [infinitude]
#### Running user/group(s)
- User: unknown
- Group: unknown
- Supplementary Groups: apps
#### Security option [no-new-privileges] is not set
- Processes can gain additional privileges through setuid/setgid binaries
- Can potentially allow privilege escalation attacks within the container
## Bug Reports and Feature Requests
If you find a bug in this app or have an idea for a new feature, please file
an issue at
https://github.com/truenas/apps
x-portals:
- host: 0.0.0.0
path: /
port: 3000
scheme: http
The only thing i would change is adding an external volume.
If you don’t provide a volume it’ll use iXVolume which may not persist for updates and/or containe restarts and you may loose your config.
Providing a hostpath like in my yaml would persist and if you ever need to reinstall the app, you can simply point it to the exisitng hostpath and wouldn’t loose the config.
