Hello everyone,
I am facing an issue in my TrueNAS Scale environment related to DNS resolution in my Kubernetes cluster. After several attempts to resolve the problem, I would like to reach out to the community for support, especially to find a solution that does not require a complete reinitialization of the cluster.
Setup and Context:
- System: TrueNAS Scale
- Version: Dragonfish-24.04.2
- CPU: AMD Athlon 3000G with Radeon Vega Graphics (2 cores, 4 threads)
- Memory: 32 GiB
- Network: Ethernet 1000Mb/s
- Docker Containers: Home Assistant and Pi-hole are running as Docker containers within this cluster.
Previous Issues:
DNS Problems with Pi-hole:
- Initially, I had issues with Pi-hole not being able to perform DNS requests properly, particularly with its own Gravity updates.
- The issue was resolved by manually setting the DNS servers in the
resolv.confto Cloudflare (1.1.1.1 and 1.0.0.1).
Home Assistant Cloud Connection Problems:
- While using Home Assistant, I encountered connection issues with the Home Assistant Cloud. The connection could not be established, even though the DNS servers were configured correctly.
- Even after adding all relevant domains to the Pi-hole whitelist and disabling DNS blocking, the problem persisted.
- It seems the same issue exists where Kubernetes does not correctly forward DNS requests.
Attempted Solutions:
Changing the resolv.conf in the Container:
- I attempted to modify the
resolv.conffile in Home Assistant to directly point to an external DNS server (Cloudflare 1.1.1.1). - This attempt failed due to permission issues within the container, as no root privileges were available.
Considering a Change to Cluster DNS:
- I considered setting the cluster DNS entry directly to the Pi-hole DNS. However, there is a risk of an infinite loop if Pi-hole forwards DNS requests back to the cluster, which then uses Pi-hole as the DNS server.
Changing Cluster DNS in TrueNAS:
- When trying to adjust the DNS entry for the cluster in TrueNAS, I encountered a warning stating that this would require a complete reinitialization of the cluster. This would result in the loss of all installed apps and data, which I am trying to avoid.
My Question to the Community:
Is there a way to adjust the DNS settings in the Kubernetes cluster such that:
- External DNS requests are forwarded correctly?
- Pi-hole can function as the DNS server without causing infinite loops?
- A complete reinitialization of the cluster is avoided?
I am looking for a solution that does not restrict functionality and ideally does not require reinstalling the entire environment. Perhaps there is a way to modify the DNS settings at a lower level or use an alternative method to manage DNS forwarding?
I would be grateful for any advice or suggestions!
Thank you in advance for your support.
Best regards,
Zorunel
