Help with offsite backup
TL;DR: I have one server and one spare drive. Is local replication the best way to create a backup for offsite storage?
The rest of it:
I’m trying to understand the best way to create a backup for the “1” in the “3-2-1” backup strategy, while still being able to update it on occasion. I’ve read into it and come across some confusing and sometimes conflicting information. Here’s my situation:
I’m running a 16TB pool (1 three-wide mirror) on a Dell T330 (TrueNAS Scale 24.10.2). I have a 4th 16TB drive which is currently unused (we’ll call it “#4”), I’d like to use that for the main offsite backup.
The only other PCs I have that support drives of that size don’t have ECC RAM, so I don’t really have reliable hardware to run a 2nd server for rsync or anything.
My (limited) research on the topic is suggesting that local replication is the best solution here. Is that the correct assumption? If so, I just have a few questions:
  1. The first time I replicate it creates a 1:1 clone of the pool, datasets, EVERYTHING -not just snapshots- to #4 correct?
  2. So if the house burns down, I can buy a new server, put #4 in, import the pool to brand new drives, and essentially be right back where I left off, correct? (The encryption key and system config are safely backed up as well).
  3. Let’s assume I copy some new stuff (Piano Recital) to my server. When I plug #4 back into the server and perform another replication task, will it redo the whole thing, only copy Piano Recital, or only the snapshot referring to Piano Recital?
Snapshots are where I start to get a bit confused. I’d hate to replicate over the years only to find out in an emergency that replication wasn’t the right method.
Is there anything else I should know, or any settings to enable/disable when performing a replication?
As a side-note, I’m not as concerned with snapshots since I’m only ever adding data and not deleting it. But again, I could be completely misunderstanding what snapshots are for.
Thank you for reading!
Dang, … exactly my question.
I was hoping to read through all the replies. :grinning_face:
Yes. It replicates up to the point of the latest snapshot you point it to.
But that means that if you, say, only take 1 snapshot every midnight, then add data the next day at 2pm and decide to replicate at 8pm, only data changes up to last midnight are replicated.
yeah local replication to that spare 16tb is the right move for your setup. no second box needed.
rough path:
  1. plug #4 in, create a new single-disk pool (call it offsite or backup). dont add it to the main mirror.
  2. Periodic Snapshot Tasks on the datasets you care about (even daily is fine if you mostly add data).
  3. Replication Tasks → local source pool/dataset → dest = the new pool. turn on recursive if you want child datasets. Auto Retry on.
  4. first run does a full seed. after that each run only sends snapshots you dont have on #4 yet (so “Piano Recital” only goes once it is inside a snapshot).
  5. when the run finishes: export the backup pool, shut down, pull #4, store it offsite.
  6. next update visit: plug #4 back, import the pool, run the replication task once, export again, leave.
answers to your specific bits:
  • first replication is a 1:1 of the chosen datasets + their snapshots, not a magical clone of the whole system disk. os/config is separate (download your TrueNAS config + secret seed and keep that with the drive).
  • house-burns recovery: new box, install scale, import the offsite pool, upload config if the shares match, or just read the data off the imported pool.
  • it will NOT resend the whole pool every time. only new snapshots since the last common one. if you waited so long that source snapshots expired, you can lose the incremental chain and it may want a full re-seed. keep snapshot lifetime longer than your offsite visit gap.
dont scrub-delete snapshots on the source until #4 has caught up at least once.
