You missed writing what exact drives you actually have.
But my first guess would be the 3.3v pin āissueā. Maybe your other PC uses molex to SATA power cables, which is one way to circumvent it, and your Thermaltake box does not?
I didnāt say molex was the issue, quite the opposite. I suggested that molex is one way of getting around the 3.3V pin problem some people face, which would explain why the drives work in another system but not in the one you want them to work in.
You mention āadaptersā, what drive comes with adapters? Please post pictures if you can.
Btw, I get 3 Google-hits total for US7SAM128, so not exactly common place drives⦠Are you sure thatās the model name? The model name would likely start with an H.
The HDD does not have molex connectors. The MB doesnāt have Molex connectors. The power supply has both Molex and Sata. I have adapters to convert Molex in Sata.
HUH721212ALE601 type US7SAM128 Sata 6.0Gb/s 7200 RPM.
If Iām not mistaken the āLā means 3.3V Power Disable.
Do you hear the drive spin?
Do as @neosfusion said: Power the drive from a 4-pin Molex power connector through a Molex-to-SATA (15-pin) adapter.
I use the exact same drives (HUH721212ALE601 and ALE600) and yes, they have to be powered from a Molex-SATA adapter unless you have a SATA 3.3-compliant server power supply. Which I always felt was a stupid way to go about it - wouldnāt making Power Disable activate when pin 3 is 0 (instead of 1) achieve the same result while retaining full backwards compabitility? Compliant power supplies would know to leave that pin unpowered, while older and consumer gear would just work. The only casualty is that Molex adapters wouldnāt work, but theyāre barely used anymore.
And USB adapters. And anything else which does not provide 3.3V, which the drive does not need and does not use for power. So it had to be done this way: Power ON to signal.
OK, so I am not sure why at the moment, but the only way I could get the disks to read is by installing a pcie sata 3 card. There must be something in the OE Bios that I am missing. I am going to investigate further.
