Having recently migrated my TrueNAS from Core to Scale due to a failing boot disk and outdated jails/plugins, the transition itself went smoothly without any problems.
Taking advantage of the Scale environment, I expanded my storage pool with new disks. Furthermore, since my services were now running through the Apps functionality, I decided to reorganize the folders within my dataset.
This involved copying a significant amount of data (around 5TB) and then deleting some, mostly duplicates. Initially, I intended to do this in one go using as few commands as possible, but I first tested the process with smaller subsets of approximately 150-200GB.
It was at this point that I began experiencing severe server slowdowns, eventually leading to system freezes.
In between some reboots, I attempted the copy/delete operations both via a Windows machine accessing my SMB share or through an SSH terminal using Linux commands.
Both methods resulted in the same issue: cp/rm operations on my dataset caused high iowait on the system (as indicated by iostat or htop), making my TrueNAS server almost unusable until the iowait subsided.
Considering that I previously performed similar manual data management tasks on my TrueNAS Core dataset without any issues, I suspect a potential incompatibility or configuration problem between TrueNAS Scale and my server setup.
However, I recognize that my expertise with TrueNAS is limited to that of an enthusiastic user, and my recent system modifications might not have always followed best practices.
Therefore, I would greatly appreciate assistance in identifying potential areas of investigation and resolution to restore my system’s stability.
My TrueNAS server
Hardware:
- MB: Supermicro X9SCM-F
- CPU: Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
- RAM: 4x8GB DDR3 PC3-12800E ECC
- NIC: Intel 82574L Gigabit
- SATA controller: Intel (onboard), LSI 9240-8i (PCIe)
HDD’s
- 5x WD WD40EFRX (CMR) 4TB = RAIDZ1 (PCIe controller)
** sda, sdb, sdc, sdd, sdf - 1x WD WDS120G2G0A SSD 120GB = boot pool (onboard controller)
** sde
Software:
System = TrueNAS SCALE ElectricEel 24.10.2.2
Apps = Radarr, Sonarr, Sabnzbd, Plex, Jellyfish (App storage connected with host paths)
Services = SMB; No encryption
Timeline of changes to the system
#1 Boot device replacement from a WD HDD Raptor to a WD SSD Green
- Disk swap + Clean install of TrueNAS Core 13.3 + Import of latest saved configuration
#2 Migration from TrueNAS Core 13.3 to TrueNAS Scale 24.04 Dragonfish
- Migrated using the CORE UI Manual Update
#3 Creation & Configuration of the Apps on Scale 24.04 to replace my Jails/Plugins
- Using the built in Apps catalog and interacting with my existing dataset
#4 Update from TrueNAS Scale 24.04 Dragonfish to TrueNAS SCALE ElectricEel 24.10.2.2
- Updated using the Scale UI Manual Update
#5 VDEV RAIDZ1 extension
- Addition of 2x WD40EFRX (CMR) 4TB, one at a time (pool went from 3 to 5)
