Home Asistant can't find my Z-WaveJS webhook location
I have a clean install of Home Assistant and also the Z-Wave JS app, which is running properly and picking up my Zwave devices. Within Home Assistant, I’m trying to add the Zwave integration but it is not finding the webhook location of the Z-Wave JS app. The Z-Wave JS UI app WS server is switched on. None of the different IP permutations are working to link the integration with the websocket. The documentation is no help. Can someone help?
I was just reading something about no inter-app communication functionality in the lateset Truenas Scale release? Is that true??! That would completely break the use of HA and Z-Wave JS UI apps together as a method to run Zwave, which is a major role of my instance. Please say this isn’t so?
