Home Assistant with Reverse Proxy
I am trying to get this running. I see in the docs you need to add
use_x_forwarded_for: true
trusted_proxies:
I assume I did this here
However, I still get
A request from a reverse proxy was received from 172.16.12.1, but your HTTP integration is not set-up for reverse proxies. Am I doing that right?
These are not environment variables.
You need to configure the config storage as a host path, then in a shell do e.g. cd /mnt/pool/appdata/homeassistant/configuration and edit the YAML file you find there according to the HA docs.
Then restart the app.
HTH,
Patrick
Ah, thanks! I thought that was the way to add the environment variables. I’ll give that a try, thanks!
