I’m using version 24.4 for the first time and I need to create users with their shared folder that they will use from Windows (so SMB).
With another version I would have created the /Home folder and then the users specifying that they had to have their own home folder; the system would have created it under Home.
Now, when I try to create /Home and specify that it is an SMB folder, the message says “TrueNAS must have at least one local SMB user before creating an SMB share.”
I did not understand.
Do I have to create the user first and then the /Home folder?
After still re-entering the user’s edit to set his home folder as sub folder of Home?
You could create the /home dataset without setting up the SMB share, then create a local user with Samba Authentication on and use the create home directory, and then set up the SMB share for /home.
That’s what I did and I hope I did well.
The /Home folder now has ACL Type “SMB/NSFv4”.
Nonetheless, in Datasets I don’t see it identified as SMB, nor do I see it in File Explorer (Windows 11 pro).
I don’t even see the user’s personal folder.
However, I can see the other folders created afterwards correctly.
Yes, the order you perform the steps matters.
First, create the share user.
Next, create the share dataset/share. In 24.04 you have the option to set these up at the same time from either the Sharing or Datasets screens if creating an SMB or NFS share. For iSCSI shares you create the dataset, then go set up the block share.
