andrea
March 19, 2025, 10:16am
Hi all,
I have 4 NVMe that are recognized by the BIOS but not by the kernel.
I have tried various distributions but the result is always the same:
“Duplicate cntlid 1 with nvme0 , subsys nqn.2018-05.com.example:nvme:nvm-subsystem-ODAHUA 20210499, rejecting”
I found a post that seems to solve the same problem by patching the kernel. (fyi, search “nvme error duplicate cntlid gentoo forums” on google)
I tried following the instructions to build TrueNAS Scale on GitHub but it seems that my changes do not end up in the package.
Have any of you ever done such a thing? How do I make sure that my changes to the kernel files are used to build the package?
Bye
Andrea
PS: Why can’t you post links or images in this forum?!?
@Andrea
Welcome!
Seems the problem is related to duplicate serial numbers.
Are you using a RAID card or a port expander? Post your full hardware configuration.
P.S. I think you can’t post links since you just joined. This is to cut down on SPAM posts.
Looks like you’re wanting to add the NVME_QUIRK_IGNORE_DEV_SUBNQN support here. In general I don’t recommend bypassing things like duplicate subsystem or UUID checks but it might be necessary.
What are the SSDs in question? I know early model Intel NVMe suffered from this.
andrea
March 19, 2025, 11:00am
4
andrea
March 19, 2025, 11:06am
5
Yes @HoneyBadger , exactly!
I’m trying to make this change to drivers/nvme/host/pci.c:
{ PCI_DEVICE(0x10ec, 0x5765), /* Skyline NVMe */
.driver_data = NVME_QUIRK_IGNORE_DEV_SUBNQN },
I take Vendor ID and Device ID from BIOS:
The problem is how do I make sure that this change is included in the TrueNAS build.
You’re following the build process here:
TrueNAS SCALE Build System
Did you use the one-step make or the multi-step process at the end?
