How to Create a Good Bug Report | Issue Reporting in Jira
We encourage all users to help us make TrueNAS the best NAS by reporting issues, requesting potentially helpful features, and relaying security vulnerabilities.
iXsystems uses Jira to track bugs and develop features. You can view public issues without logging in, but you must create an Atlassian account to report bugs or suggest features.
Submitting Bug Reports In Jira
Go to the TrueNAS project on Jira and click Create in the top bar.
Create Ticket
Set the Issue Type to Bug. The form reloads with more fields. Do not select the Defect option which is only for internal use.
Developers use most of the fields on bug tickets, but you should fill out the Summary and Description to provide a usable report.
The Summary is a short, descriptive title that helps developers find the issue and understand the topic.
The Description lets you enter specific issue details.
A good bug report includes these elements:
  • A brief, specific, description detailing the problem you encountered.
  • The steps to reproduce the issue. A simple list of the steps you took to see the issue is fine.
  • An explanation of what should have happened while taking the steps listed above.
  • A description of what actually happened while taking the steps listed above.
  • The TrueNAS software version you are using, which is found on the main Dashboard.
  • The current service configuration if the bug is service-related to help developers replicate your system.
  • Any additional details you think can help the developer investigate.
In addition to the above information, please also provide:
  • A TrueNAS debug file. This is required to help developers identify and troubleshoot issues on your system.Include a console log if the error is a web interface issue. If unsure how to save these, see the Adding a Debug File to a Report and Web Console Log sections in this article.
  • The core file if your system produces a core file error. Save the file and attach it to your ticket.
  • Screenshots if the bug is a web interface glitch or a formatting problem.
  • A video if screenshots do not adequately show the issue.
When finished filling out the all fields (i.e., Summary, Description, Affects Version, etc.), click Create at the bottom of the form.
Submit Ticket
Developers review and update the ticket if/when they need additional information. The Jira account receives emails about the ticket status. Developers might request more details as they work to resolve the issue, so check the ticket periodically.
Making Feature Suggestions
Want to see a new feature added to TrueNAS? You can see and vote for community-proposed features in the TrueNAS Jira project and make your feature suggestions here. If you find a suggestion that you want to see implemented, open that ticket and click Vote for this issue in the People section.
Voting for a Suggestion
Figure 1: Voting for a Suggestion
To suggest a new feature, go to Jira, log in to your Jira account, and click Create.
Creating a New Suggestion
Figure 2: Creating a New Suggestion
Briefly describe the new feature you would like to see added in the Summary section. After creating your feature suggestion, it moves to the Gathering Interest stage, where the community can review and vote for the feature. After gathering enough interest, the TrueNAS Release Council reviews the suggestion for feasibility and determines where to add the feature in the software roadmap.
Security Issues
See https://security.truenas.com/ for security advisories and software bill of materials for specific TrueNAS releases.
Security issues do not appear on public issue trackers due to their sensitive nature. If you have discovered a suspected security vulnerability in the latest version of a software release, you can report this directly to the Security Team.
Downloading a Debug File
The TrueNAS web interface lets users save debugging information to a text file.
On TrueNAS CORE systems, go to System > Advanced and click SAVE DEBUG.
Generate Debug Warning
Figure 3: Generate Debug Warning
Click PROCEED to generate the debug file (might take a few minutes). After generating the debug file, TrueNAS prompts you to download it to your local system and saves a copy in /var/tmp/fndebug.
The freenas-debug command-line utility collects debugging information.
Debug files contain log files which can include personal information such as usernames, networking configuration, device serial numbers, or other identifying information about your system. Files uploaded to an issue from the System > Support screen using Attach Debug or through the Jira Private File Upload service are only visible to iXsystems engineers. The iXsystems Privacy Policy contains a detailed statement of our commitment to data privacy.
Always store debug files in a secure location. Please review debugs and redact any sensitive information before sharing with external entities. Use a file archiver utility, such as 7-zip, to open compressed debug archives and review log contents.
On TrueNAS SCALE systems, go to System Settings > Advanced, then click Save Debug and wait for the file to download to your local system. Generating the debug file might take a few minutes to complete. After that, it downloads to your system.
Adding a Debug File to a Jira Ticket
Jira provides a public-facing area for files that do not require privacy. iXsystems also provides a secure file attachment area that only developers can access, where you can upload files with sensitive information like a system debug or screenshot of network connections.
Debug files attached directly to the Jira issue ticket are visible to other users searching and reading Jira issue tickets. To keep your sensitive information private, use the link in the system-generated message posted to your Jira ticket to upload files to the private attachment area. Be sure to link your file uploads to your Jira ticket number before you click Save after uploading your file.
If you are not concerned about data privacy, you can attach the debug, core, log, or other files to the Jira ticket.
Attaching Files to New Tickets
Drag and drop public-facing files into the Attachment box when creating a new ticket:
To protect your privacy, please use the link in the system-generated message to upload your debug or any screenshot with sensitive information to the private file attachment area. Link this upload to your Jira issue ticket so developers can locate the file. Files uploaded to this service are only visible to project developers.
Attaching Files to Existing Tickets
For public facing files, open the ticket in your browser and either click Attach, at the top of the ticket, or click the +, in the Attachments section, to open a local system file browser to select the files. You can also drag and drop the file onto the Attachments box and add any comments about it.
Upload private files to our secure private upload service located at Jira Service Management. Files uploaded to this service are only visible to project developers.
Is this outdated and no longer valid?
I can’t create a bug report, since I don’t have write access to anything under the TrueNAS Project, even after creating an Atlassian account.
It should be mostly up to date, other than some screenshots of the Jira UI at least.
Are you sure you have issue type set to Bug? There are some types that may be restricted.
You can also try the Send Feedback button in the TrueNAS UI and click Report a Bug:
I am following the steps described in here and in the docs to create a ticket on Jira directly.
After clicking create in the top bar:
Bitte loggen Sie sich ein.
It looks like you’re not currently logged in to your account in Jira. Try clicking the icon in the top right to log in.
But I am. I tried it with Firefox, with Safari, with Apple Login and with classic mail + password login.
Clicking on the top right, does only a refresh, since it recognizes I am already logged in.
Might be an issue to take up with Jira/Atlassian then. This is what that toolbar looks like when I’m logged in:
And if I’m not logged in:
You could maybe try some of these suggestions? Troubleshoot login issues with your Atlassian account | Atlassian Support
Now it works. Seems like there was a Jira hiccup :blush:
Sorry for wasting our time.
I’m having the same issue. Tried logging into Atlassian/Jira under two different accounts with both Firefox and Chrome. ixsystems-atlassian-net is showing me logged in. As soon as I click on “Create” I get a popup saying “You are not authorized to perform this operation. Please log in.” So, my question is whether any authenticated Atlassian user is supposed to be able to create bug reports, or if there is a smaller group of authorized bug reporters?
Same as @e2b I’m not able to create bug report I get “You are not authorized to perform this operation. Please log in.” while being logged in.
HI
I’m logged into into Atlassian, but I’m unable to create an issue. The ‘Create’ button doesn’t do anything.
Ive tried two different browsers.
Is there something else I need to do in order to create an issue?
Try directly from the truenas webui (smiley button top right corner), i believe new users don’t have the correct permissions if you try it directly in jira
Thank you very much LarsR - that did the trick!
That was very definitely non-obvious!
I’m not able to create an issue either: I am logged in, and tried in two different browsers (Firefox and Brace), but it says I don’t have permission to perform that action when clicking the ‘Create’ button on the top bar. Unfortunately I can’t use @LarsR ‘s work around to use the trunas webui, as my bug is that I can’t login to my truenas anymore due to the login screen hanging.
Attaching screenshot showing the lack of permission:
If you’re getting “not authorized” errors in Jira, try using the Send Feedback button in the TrueNAS web UI instead - that smiley face icon top right usually works.
