How to increase max sequential data throughput for RAIDZ3? More VDEVs?
I use TrueNAS as a home backup server, and I want to speed up the process of copying the weekly backups from my PCs.
They’re all on a 10Gbit network, but my server’s write speed seems limited to that of one spinning drive.
Might adding some identical VDEVs in mirrors increase the write speed, or is there a way to stripe them?
Perhaps there’s another option to get faster sequential write speeds from my RAIDZ3 array? (Other than upgrading to SSDs?)
A rule of thumb is that a single vdev has the write speed of a single drive. So adding more RAIDZ3 vdevs will probably help, the largest gain from the first one you add, because that would double the speed.
All vdevs in a pool are striped. There is no option here. All vdevs should have the same topology, so you need to add another RAIDZ3.
IOPS vs. Throughput
That is factually incorrect. The number of write IOPS is the same per vDev, but the actual data throughput is based on the number of non-redundant drives in the pool.
The IOPS only becomes the limit when you are doing a lot of small reads or writes - otherwise it is throughput. And this is normally for virtual disks/zVolumes/iSCSI or database tables which do small 4KB reads and writes, and in this case what is even more important than using mirrors for IOPS is using mirrors to avoid read and write amplification.
So using 18x drives in 9x mirrored vDevs won’t have any more write throughput than using 12x drives in 1x RAIDZ3 vDev.
Expectations
@Lylat1an doesn’t give a lot of information about your pool layout except that it is RAIDZ3. A typical HDD has a peak write throughput of 150-250MB/s i.e. 1.2-2.0Gb/s though this includes writing metadata blocks for each TXG (which are not sent over the network) and doesn’t take into account the significant time taken for seeks. If we assume (optimistically) that you will get 100MB/s or 800MB/s throughput per drive, and that metadata write overhead is 10% then you will need 14+ data drives to be able to max out a 10GB network i.e. your RAIDZ3 pool would need to be 2x 10-wide RAIDZ3.
To achieve the same thing with mirrors and the same redundancy would require 14x 4-wide mirrors i.e. 56 drives!!!
Cause of actual results
Again, OP doesn’t give details of pool design or actual throughput, but throughput of a single drive sounds too low. If this is true then it sounds to me like he is doing synchronous writes i.e. a dataset configuration error.
Thank you for responding, my pool consists of 8x 4TB drives.
I kept an eye on a 700GB transfer yesterday, and it didn’t go much faster than 125mb/s
I was copying from a Samsung 990 Pro NVMe drive that’s dedicated to holding backups to be copied, and there’s another one in the server to receive them.
Now that I think about it, I tried sending the backup to the server’s SSD first, and got slightly less performance, perhaps my network settings are wrong…
Update: I tried copying the backup from the pool back to the SSD on my main PC, and I’m getting up to 173 MB/s. So perhaps the network is working properly, and the pool’s writes are the limiting factor.
If you are getting slow writes to the NVMe SSD on the NAS and getting the same results, then the most likely cause is IMO synchronous writes.
However, if you are getting slower writes to HDD, then it could also be that your 4TB drives are SMR - what exact models are they?
It also depends in part on the config of pool. My puny pool with a single Z3 VDEV and a sVDEV manages to eek out 400MB/s on a pretty sustained basis when I’m transferring large files, at least according to the MacOS Activity Monitor measuring data throughput.
“Smaller” files or large collections of files (think rsync transferring sparse-bundle bands for Time Machine) will lower my network throughput.
Do not discount the positive impact that a sVDEV can have by pushing small files and metadata to the sVDEV (which usually consists of SSDs) while the larger files move to the HDD-based VDEV(s). This on a pretty standard 10GbE network without using jumbo packets, etc.
Maybe worth doublechecking, can you post the output of ifconfig?
@Protopia: My drives are HGSTs, model HUS726040AL4210.
@Constantin: I do have a few SATA SSDs laying about that I could add…
@Neofusion:
ens15: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500' 'inet 10.0.0.3 netmask 255.255.255.0 broadcast 10.0.0.255' 'inet6 2601:603:100:9450:217:b6ff:fe00:5800 prefixlen 64 scopeid 0x0<global>' 'inet6 fe80::217:b6ff:fe00:5800 prefixlen 64 scopeid 0x20<link>' 'ether 00:17:b6:00:58:00 txqueuelen 1000 (Ethernet)' 'RX packets 3259 bytes 1054507 (1.0 MiB)' 'RX errors 0 dropped 0 overruns 0 frame 0' 'TX packets 749 bytes 169037 (165.0 KiB)' 'TX errors 0 dropped 2 overruns 0 carrier 0 collisions 0
That looks incomplete, it lacks the local loopback interface for example, can you please post the full output?
Also, before you hit reply, please select the pasted output and press the </> button in the forum toolbar to make it readable.
Thanks for the correction. I probably confused IOPS and throughput.
Sorry, I posted the output of the interface I use.
Here’s the complete output:
eno1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether ac:1f:6b:47:0e:be  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 29 overruns 0  carrier 0  collisions 0
        device memory 0xfbc20000-fbc3ffff
eno2: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether ac:1f:6b:47:0e:bf  txqueuelen 1000  (Ethernet)
        TX errors 0  dropped 34 overruns 0  carrier 0  collisions 0
        device memory 0xfbc00000-fbc1ffff
        RX packets 14096  bytes 4830715 (4.6 MiB)
        TX packets 1572  bytes 300310 (293.2 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 3465  bytes 1600188 (1.5 MiB)
        TX packets 3465  bytes 1600188 (1.5 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
Read the sVDEV resource in detail before you go down that path.
