How to recover from rm -rf /* ? (lost everything)
I’ve already considered many areas where it needs to work with the middleware and GUI. Not a programmer myself, but I have a fundamental understanding of the places that need “checks” before proceeding.
Here’s an example.
You visit the page in the GUI to remove a vdev from the pool. The middleware’s “things to check” include “Does this pool have a checkpoint?” If so, it will alert the user, without continuing.
The above scenario is actually ideal, since it favors safety over speed and convenience, where it concerns pool management via the GUI.
Ask any user with a NAS: “Would you rather have no safety net whatsoever when managing your pool, or would you be okay with a rudimentary safety net, but at the cost that you might be ‘inconvenienced’ when trying to remove a vdev?”
I’m sure most users would say: “That’s totally fine. If removing a vdev takes a minute longer to proceed, since I have to remove a checkpoint first, then it’s worth the added safety net to give me a chance of avoiding an irreversible disaster or accident.”
…you have users that can read or listen? Where can I buy such users?
I can sell you some for 5 BTC. I know you have the money, from an earlier “legal” transaction.
@Berboo Highly recommended to check (burn in) the new drive before using it to make sure it is up to the task:
You definitely do not want your backup to end up on a broken disk.
Hi everyone,
I’m back with some updates.
First of all, I managed to recover almost all my data. I say “almost” because I might have missed some files that I didn’t notice, but for the most important ones, I made backups.
I saved everything I needed on the 4TB drive I bought, using a SATA-to-USB cable. It took quite a while due to the low transfer speed.
I’ve just finished that step and started importing the pool following @HoneyBadger’s commands:
root@truenas[~]# zpool export TankPrincipal
cannot export 'TankPrincipal': pool is busy
root@truenas[~]#
I encountered the same issue we had when trying to mount the pool after the import. However, I didn’t spend much time troubleshooting it—I simply rebooted the server and executed the following command a few moments ago:
root@truenas[~]# zpool import TankPrincipal -fFXT 10443235 -R /mnt -N -o cachefile=/data/zfs/zpool.cache &
[1] 4640
root@truenas[~]#
Next steps:
If the import completes successfully and the server is back up and running, I’ll run the script suggested by @MSameer (thanks, @MSameer!) on the new 4TB drive (where I have backed up my data) to replace the one with bad sectors.
After that, I’ll create snapshots for the most important datasets.
Thanks again guys !
Edit :
root@truenas[~]# jobs
root@truenas[~]#
How to know if the import is still processing ?
As an aside: when it’s all recovered, don’t forget to look into
My heart skipped a beat when I read the data was there. I just did not want to introduce noise by saying it at that time.
That was an amazing moment given my past experiences with recovering data accidentally deleted.
To everyone who helped and especially @HoneyBadger, no amount of thank you will do you justice.
This community is really amazing.
NO. PLEASE DO NOT.
The burn in script is destructive. It is meant for new empty drives.
It will destroy your back ups if you run it on a full drive.
I know.
But I will run that script AFTER the import that is currently running completes successfully.
Once I make sure that the second -R import is ok, I will have to replace the dying drive. I’ll set some snapshots on the important datasets and then think about the 3 copies back up strategy.
What’s wrong with this ? :point_up:
Edit :
I think I’ll go like this after the import :
  1. I’ll disconnect the dying drive.
  2. Let the pool resilver. If anything goes wrong, I still have the data on the new hard drive.
  3. If the pool is up and running after resilvering, I’ll run the script that check the health of the new drive and if it’s fine I’ll put it in place.
So it seems that the Pool is back ONLINE. But I can’t see it in the UI. When I click the dataset in the menu I got the same error I had few days ago :
root@truenas[~]# zpool status
  pool: TankPrincipal
 state: ONLINE
  scan: scrub repaired 0B in 04:38:20 with 0 errors on Sat Nov  9 19:38:22 2024
        NAME                                                STATE     READ WRITE        CKSUM
        TankPrincipal                                       ONLINE       0     0        0
          raidz1-0                                          ONLINE       0     0        0
            ata-WDC_WD40EFRX-68WT0N0_WD-WCC4E1878897-part2  ONLINE       0     0        0
            ata-WDC_WD40EFRX-68WT0N0_WD-WCC4E1852520-part2  ONLINE       0     0        0
            ata-WDC_WD40EFRX-68WT0N0_WD-WCC4EHAH8F79-part2  ONLINE       0     0        0
errors: No known data errors
  pool: boot-pool
 state: ONLINE
          sdc3      ONLINE       0     0     0
Is the Pool completely Online ? Do I need to do something else ? Maybe it has something to do with the -N option ?
root@truenas[~]# zpool get all TankPrincipal | grep feature
TankPrincipal  feature@async_destroy          enabled                        local
TankPrincipal  feature@empty_bpobj            active                         local
TankPrincipal  feature@lz4_compress           active                         local
TankPrincipal  feature@multi_vdev_crash_dump  enabled                        local
TankPrincipal  feature@spacemap_histogram     active                         local
TankPrincipal  feature@enabled_txg            active                         local
TankPrincipal  feature@hole_birth             active                         local
TankPrincipal  feature@extensible_dataset     active                         local
TankPrincipal  feature@embedded_data          active                         local
TankPrincipal  feature@bookmarks              enabled                        local
TankPrincipal  feature@filesystem_limits      enabled                        local
TankPrincipal  feature@large_blocks           enabled                        local
TankPrincipal  feature@large_dnode            disabled                       local
TankPrincipal  feature@sha512                 enabled                        local
TankPrincipal  feature@skein                  enabled                        local
TankPrincipal  feature@edonr                  disabled                       local
TankPrincipal  feature@userobj_accounting     disabled                       local
TankPrincipal  feature@encryption             disabled                       local
TankPrincipal  feature@project_quota          disabled                       local
TankPrincipal  feature@device_removal         disabled                       local
TankPrincipal  feature@obsolete_counts        disabled                       local
TankPrincipal  feature@zpool_checkpoint       disabled                       local
TankPrincipal  feature@spacemap_v2            disabled                       local
TankPrincipal  feature@allocation_classes     disabled                       local
TankPrincipal  feature@resilver_defer         disabled                       local
TankPrincipal  feature@bookmark_v2            disabled                       local
TankPrincipal  feature@redaction_bookmarks    disabled                       local
TankPrincipal  feature@redacted_datasets      disabled                       local
TankPrincipal  feature@bookmark_written       disabled                       local
TankPrincipal  feature@log_spacemap           disabled                       local
TankPrincipal  feature@livelist               disabled                       local
TankPrincipal  feature@device_rebuild         disabled                       local
TankPrincipal  feature@zstd_compress          disabled                       local
TankPrincipal  feature@draid                  disabled                       local
TankPrincipal  feature@zilsaxattr             disabled                       local
TankPrincipal  feature@head_errlog            disabled                       local
TankPrincipal  feature@blake3                 disabled                       local
TankPrincipal  feature@block_cloning          disabled                       local
TankPrincipal  feature@vdev_zaps_v2           disabled                       local
TankPrincipal  feature@redaction_list_spill   disabled                       local
TankPrincipal  feature@raidz_expansion        disabled                       local
TankPrincipal  feature@fast_dedup             disabled                       local
root@truenas[~]#
Correct.
@HoneyBadger, will a reboot automatically import the pool without the “no mount” (-N) flag? In other words, any command-line work is “done”, and now it’s back to business as usual with the GUI only?
Or as it is said in the output I posted above, do a :
zpool upgrade
Don’t touch that! At least, not yet.
I believe after the successful (non-read-only) import via the command-line, you are to reboot the server, which will handle things automatically like normal.
I’ll wait for @HoneyBadger to confirm.
@Berboo your services and middleware will be upset about the pool being offline/online again. If it successfully imported in read/write mode, a subsequent reboot should import without issue.
After the reboot :
  pool: boot-pool
 state: ONLINE
          sdd3      ONLINE       0     0     0
root@truenas[~]#
:thinking:
Use Add/Import pool in the top corner of the Storage dashboard.
Quoting my own post here, but isn’t that manually created folder going to be a problem right about now?
Edit: I’m happy I was wrong on this. :slight_smile:
I don’t know.
After the manual import I have just did as @HoneyBadger suggested. I’ll reboot again see how it goes now
EDIT : reboot successful. The server is back and running as if I had never erased anything. I didn’t have to manually import the pool.
So amazing !
This is brilliant news! I’m delighted.
