Hi. I have built a HP-Z800 TrueNAS home server. I run this as a headless server where my only access is through webGUI. (I do have physical access to the machine but it is set up without screen or keyboard).
When/if this machine for some reason freezes up or I cannot access it, it could be nice to trigger a soft shutdown from the power button on the machine. If I press the power button now, it acts like a full sudden kill.I could not see any settings in BIOS for this. Is there any setting in TrueNAS for this?
I run TrueNAS-13.0-U6.2
Can this be set via F10 → Power → OS Power Management?
The power button should trigger an ACPI shutdown.
What is the output of ‘dmesg |grep -i acpi’?
A whole ton…
From all the warnings, it looks like everything is wrong here…
I see acpi0: Power Button (fixed)
Does that tell anything?
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
ACPI APIC Table: <HPQOEM TYLSBURG>
Firmware Warning (ACPI): 32/64X length mismatch in FADT/Pm1aEventBlock: 32/16 (20201113/tbfadt-748)
Firmware Warning (ACPI): 32/64X length mismatch in FADT/Gpe0Block: 128/32 (20201113/tbfadt-748)
Firmware Warning (ACPI): Invalid length for FADT/Pm1aEventBlock: 16, using default 32 (20201113/tbfadt-850)
acpi0: <HPQOEM SLIC-WKS>
cpu0: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
hpet1: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0xf808-0xf80b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Firmware Error (ACPI): Failure creating named object [\134_SB.PCI0._OSC.CAPD], AE_ALREADY_EXISTS (20201113/dsfield-352)
ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20201113/dswload2-639)
ACPI Error: Aborting method \134_SB.PCI0._OSC due to previous error (AE_ALREADY_EXISTS) (20201113/psparse-689)
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> at device 3.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> at device 7.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> irq 20 at device 28.0 on pci0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> irq 20 at device 28.4 on pci0
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> irq 21 at device 28.5 on pci0
pci6: <ACPI PCI bus> on pcib6
pcib7: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci7: <ACPI PCI bus> on pcib7
pcib8: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci8: <ACPI PCI bus> on pcib8
pcib9: <ACPI PCI-PCI bridge> at device 3.0 on pci8
pci9: <ACPI PCI bus> on pcib9
pcib10: <ACPI PCI-PCI bridge> at device 7.0 on pci8
pci10: <ACPI PCI bus> on pcib10
pcib11: <ACPI PCI-PCI bridge> at device 9.0 on pci8
pci11: <ACPI PCI bus> on pcib11
pcib12: <ACPI Host-PCI bridge> on acpi0
pci12: <ACPI PCI bus> on pcib12
acpi_button0: <Power Button> on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
acpi0: Power Button (fixed) appears on my machine, so I don’t think there is a problem.
Firmware Error (ACPI): is the problem.
If you have a PCIe card, that might be the cause, but i don’t know.
If the machine freezes you cannot trigger a soft shutdown.
Anyway, you want to look for IPMI if you don’t want to use the button.
Ok, good info. Thanks
Ok, I should probably dig into those error messages then. Thanks
