I’m trying to setup a bridge, and I was following these instructions : SOLVED - Bridge connections not working? | TrueNAS Community
The problem is that I can’t reset the network interface in use (see the following error) :
error VALIDATION
[EINVAL] interface.delete: Interface is in use by kubernetes
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 201, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1342, in _call
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 188, in delete
return await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 197, in nf
rv = await func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/network.py", line 1403, in do_delete
verrors.check()
File "/usr/lib/python3/dist-packages/middlewared/service_exception.py", line 70, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] interface.delete: Interface is in use by kubernetes
I have stopped all apps and VM, I also tried to stop all the services and unset the pool of my app…
