Immich and iGPU (Alder Lake, 12th)
Has anyone managed to get iGPU (N100, Alder Lake, 12th Gen) working on TrueNAS Scale (24.10) with the immich app? I used the passthrough GPU option, but facial recognition still uses CPU. The docs - Hardware Transcoding | Immich - don’t have anything specific for the 12th Gen Intel GPU. Should I have enabled something?
What I can confirm is that it does work with Plex - using Passthrough available (non-NVIDIA) GPUs so the OS can utilise it, but using the same option on immich doesn’t change anything.
Can anyone help?
i don’t think you can use your i GPU for apps if you only have one gpu because truenas needs at lease one GPU for itself to understanding i have a tesla m40 andi used NVIDIA smi to verify that immich was using the gpu for video Transcoding and im not sure if checking the “use non nvdia gpu” box will use you igpu
