Hello Everyone,
i am super new at NAS, TrueNAS, and Immich. so i got tried of google photo and i am looking to use Immich as a replacement.Eeverything seems to work well except for the machine learning search. i have tried searching the forum to find a solution but i have come up empty.
I have a GeForce GTX 980 which is right at the minimum requirements for using CUDA machine learning, that being said even when i use the default i still get the “smart search error”
when i try to change the setting to use my GFX card, i get this error:
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 515, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 562, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 622, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 619, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 294, in nf
rv = func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 101, in wrapped
result = func(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 229, in do_update
app = self.update_internal(job, app, data, trigger_compose=app[‘state’] != ‘STOPPED’)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 259, in update_internal
update_app_config(app_name, app[‘version’], new_values, custom_app=app[‘custom_app’])
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py”, line 60, in update_app_config
render_compose_templates(
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py”, line 51, in render_compose_templates
raise CallError(f’Failed to render compose templates: {cp.stderr}')
middlewared.service_exception.CallError: [EFAULT] Failed to render compose templates: Traceback (most recent call last):
File “/usr/bin/apps_render_app”, line 33, in
sys.exit(load_entry_point(‘apps-validation==0.1’, ‘console_scripts’, ‘apps_render_app’)())
File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 48, in main
render_templates_from_path(args.path, args.values)
File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 19, in render_templates_from_path
rendered_data = render_templates(
File “/usr/lib/python3/dist-packages/catalog_templating/render.py”, line 31, in render_templates
rendered_templates[i.name] = env.get_template(i.name).render(
File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 1301, in render
self.environment.handle_exception()
File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File “/mnt/.ix-apps/app_configs/immich/versions/1.9.15/templates/docker-compose.yaml”, line 12, in top-level template code
{% set postgres = tpl.deps.postgres(values.consts.pgvecto_container_name, “pgvecto_image”, pg_config, perm_container) %}
File “/mnt/.ix-apps/app_configs/immich/versions/1.9.15/templates/library/base_v2_1_45/deps.py”, line 28, in postgres
return PostgresContainer(self._render_instance, name, image, config, perms_instance)
File “/mnt/.ix-apps/app_configs/immich/versions/1.9.15/templates/library/base_v2_1_45/deps_postgres.py”, line 48, in init
c = self._render_instance.add_container(name, image)
File “/mnt/.ix-apps/app_configs/immich/versions/1.9.15/templates/library/base_v2_1_45/render.py”, line 63, in add_container
container = Container(self, name, image)
File “/mnt/.ix-apps/app_configs/immich/versions/1.9.15/templates/library/base_v2_1_45/container.py”, line 102, in init
self.deploy: Deploy = Deploy(self._render_instance)
File “/mnt/.ix-apps/app_configs/immich/versions/1.9.15/templates/library/base_v2_1_45/deploy.py”, line 15, in init
self.resources: Resources = Resources(self._render_instance)
File “/mnt/.ix-apps/app_configs/immich/versions/1.9.15/templates/library/base_v2_1_45/resources.py”, line 24, in init
self._auto_add_gpus_from_values()
File “/mnt/.ix-apps/app_configs/immich/versions/1.9.15/templates/library/base_v2_1_45/resources.py”, line 55, in _auto_add_gpus_from_values
raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]")
base_v2_1_45.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]
any suggestions on how i can fix this issues get get searching to work??
TIA
