Immich permsion exited
I Just install a new immich app with 2 hard drives, one for data and one for thumbs and database. I have everything running except permision. I have this error:
2025-02-13 18:19:48.564924+00:00=== Applying configuration on volume with identifier [pgvecto_postgres_data] ===
2025-02-13 18:19:48.564966+00:00Path [/mnt/permission/pgvecto_postgres_data] is not empty, skipping...
2025-02-13 18:19:48.564981+00:00=== Applying configuration on volume with identifier [redis_redis_data] ===
2025-02-13 18:19:48.564994+00:00Path [/mnt/permission/redis_redis_data] is a temporary directory, ensuring it is empty...
2025-02-13 18:19:48.565014+00:00Current Ownership and Permissions on [/mnt/permission/redis_redis_data]:
2025-02-13 18:19:48.565026+00:00Ownership: wanted [1001:0], got [1001:0].
2025-02-13 18:19:48.565038+00:00Permissions: wanted [None], got [0775].
2025-02-13 18:19:48.565051+00:00---
2025-02-13 18:19:48.565070+00:00Ownership is correct. Skipping...
2025-02-13 18:19:48.565082+00:00Skipping permissions check, chmod is falsy
2025-02-13 18:19:48.565094+00:00Time taken: 0.27ms
2025-02-13 18:19:48.565106+00:00=== Finished applying configuration on volume with identifier [redis_redis_data] ==
2025-02-13 18:19:48.565118+00:002025-02-13T18:19:48.565118836Z
2025-02-13 18:19:48.565138+00:00Total time taken: 0.31ms```
Thanks for your help
Is this the right path
/mnt/permission/...
to your volumes?
I don’t have that folder created. I should create it? Immich didn’t ask to path that folder in the installation
did you ever figure this one out
There is no error here, this should not stay running, its a transient container.
And no, you should NOT create the /mnt/permission path, its just a path inside the temporary container.
Good to know. How do you know when a container is meant to be exited or if its a fault?
Does this container just start when launched to verify credentials then close?
