After having to reinstall Truenas scale on my VM and importing the pool i got this Error message:
“Pool state is DEGRADED: One or more devices could not be used because the label is missing or invalid. Sufficient replicas exist for the pool to continue functioning in a degraded state”
Cant acess data trhougth smb, but i do have backups, ran 2 scrub tasks still have the error, smart test wont run.
is there anything i can do to solve this that doesnt envolve replacing the drive, would formating the drive and rebuilding the pool from scratch fix this?
Truenas scale version: 25.04.1
4 cores of 28x Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
8 Gb ram
Virtualized on proxmox
disk is on pastrhough
zpool status output
pool: PMC-STORAGE
state: DEGRADED
status: One or more devices could not be used because the label is missing or
functioning in a degraded state.
action: Replace the device using ‘zpool replace’.
see: (cant include link on post)
scan: scrub repaired 0B in 01:51:05 with 0 errors on Tue Jul 29 15:14:19 2025
NAME STATE READ WRITE CKSUM
PMC-STORAGE DEGRADED 0 0 0
29d2ea99-cc18-4e19-ac51-113cba64c8af DEGRADED 0 0 0 too many errors
cache
cdbe6d24-b655-4963-b946-62d8e5596e7c UNAVAIL 0 0 0
errors: No known data errors
pool: boot-pool
state: DEGRADED
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
using ‘zpool clear’ or replace the device with ‘zpool replace’.
boot-pool DEGRADED 0 0 0
sda3 DEGRADED 0 0 0 too many errors
lsblk output
root@truenas:/# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 64G 0 disk
├─sda1 8:1 0 1M 0 part
├─sda2 8:2 0 512M 0 part
└─sda3 8:3 0 63.5G 0 part
sdb 8:16 0 1.8T 0 disk
├─sdb1 8:17 0 2G 0 part
└─sdb2 8:18 0 1.8T 0 part
sdc 8:32 0 931.5G 0 disk
├─sdc1 8:33 0 2G 0 part
└─sdc2 8:34 0 929.5G 0 part
