What is working wrong?
I tried to install JDownloader2 with TrueNas Charts but it dont install correct.
[EFAULT] Failed to install chart release: Error: INSTALLATION FAILED: parse error at (jdownloader2/charts/common/templates/lib/pod/_volumes.tpl:103): function "break" not defined
You’re trying to install a truecharts catalog app, not a truenas catalog app.
You need to upgrade scale to cobia 23.10.x. bluefin 22.12.x is no longer supported with truecharts apps (system settings → update. select cobia from the dropdown).
