Its my first time using TrueNAS and i’m trying to install Nextcloud using the apps feature but it keeps giving me the same error. I tried some solutions i found online but that doesn’t seem to resolve the issue.
This is the error i’m getting
[EFAULT] Failed to render compose templates: Traceback (most recent call last): File "/usr/bin/apps_render_app", line 33, in sys.exit(load_entry_point('apps-validation==0.1', 'console_scripts', 'apps_render_app')()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 47, in main render_templates_from_path(args.path, args.values) File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 36, in render_templates ).render({'ix_lib': template_libs, 'values': test_values}) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render self.environment.handle_exception() File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception raise rewrite_traceback_stack(source=source) File "/mnt/.ix-apps/app_configs/nextcloud/versions/1.5.8/templates/docker-compose.yaml", line 53, in top-level template code {% do tpl.funcs.disallow_chars(values.nextcloud.redis_password, ["&", "@", "#", "%"], "redis_password") %} ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/nextcloud/versions/1.5.8/templates/library/base_v2_1_6/functions.py", line 94, in _disallow_chars raise RenderError(f"Disallowed character [{char}] in [{key}]") base_v2_1_6.error.RenderError: Disallowed character [@] in [redis_password]
More info
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 509, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 556, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1367, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 268, in nf
rv = func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf
res = f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 203, in do_create
return self.create_internal(job, app_name, version, data['values'], complete_app_details)
File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 248, in create_internal
raise e from None
File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 233, in create_internal
update_app_config(app_name, version, new_values)
File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 59, in update_app_config
render_compose_templates(
File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 50, in render_compose_templates
raise CallError(f'Failed to render compose templates: {cp.stderr}')
middlewared.service_exception.CallError: [EFAULT] Failed to render compose templates: Traceback (most recent call last):
File "/usr/bin/apps_render_app", line 33, in <module>
